Is this a good price for a 08 FSRxc Pro?
My LBS is selling a carryover 08 FSRxc Pro for $1600 (which he says is negotiable). Does this sound like a good deal? The specs seem pretty solid. Can anyone help a noob out? I came pretty close to buying it but told him I would think it over.
FRAMEFSR M4 butted frame w/ ORE downtube, sealed cartridge bearing pivots, replaceable hanger, bolt on cable guides, two sets of water bottle bosses, disc only, 100mm travel
REAR SHOCKFox Triad II, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, rebound adjust, 7.0x1.6"
FORKRock Shox Reba SL, Air, 100mm travel, 32mm stanchions, disc only, alloy steerer, Motion Control damper, lockout and rebound adjust
HEADSET1 1/8" threadless, black steel cups, loose ball bearings w/ seals
STEMSpecialized 3D forged adjustable rise, 31.8mm clamp, S:75mm, M:90mm, L/XL:105mm
HANDLEBARSSpecialized XC low rise 31.8mm bar, 6066 butted alloy, 640mm wide, 6 degree up, 8 degree backsweep
TAPE/GRIPSSpecialized MTB, dual density
FRONT BRAKECustom Avid Juicy 3 SL, hydraulic disc, G2 Clean Sweep rotor S/M: 180mm, L/XL 203mm
REAR BRAKECustom Avid Juicy 3 SL, hydraulic disc, G2 Clean Sweep rotor S/M: 160mm, L/XL: 203mm
BRAKE LEVERSAvid Juicy 3 SL hydraulic Custom
FRONT DERAILLEURShimano Deore M530, 34.9mm clamp
REAR DERAILLEURShimano Shadow XT M772, SGS cage
SHIFT LEVERSShimano Deore M530, 9-speed trigger
CASSETTE FREEWHEELShimano HG-50, 9-speed, 11-34t
CHAINKMC HG 73 w/ reusable Missing Link
CRANKSETShimano M532, 2pc design, 9-speed, replaceable rings w/ alloy outer
CHAINRINGS22S/32S/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKETShimano outboard cartridge bearing design integrated w/ M532 2pc crank
PEDALSShimano 505 SPD
RIMSDT-Swiss 445D, 26", double wall disc, pin joint, eyelets, 32h
FRONT HUBSpecialized Hi Lo disc, 32h, cartridge bearing disc, CNC flange and disc mount, QR
REAR HUBShimano M-475L disc, 32h, 8/9-speed cassette, alloy QR
SPOKES1.8mm (15g) stainless, black, alloy nipples
FRONT TIRESpecialized The Captain Control, 26.2.0", tubeless ready, aramid bead
REAR TIRESpecialized The Captain Control, 26.2.0", tubeless ready, aramid bead
TUBESSpecialized Ultralite, .6mm, presta
SADDLESpecialized MTB, 7mm hollow Cr-Mo rails, SL foam
SEAT POST2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDERAlloy collar w/ QR, 34.9mm clamp ID, black
Looks like a good deal to me, seems similar to the 09 FSRxc Expert that retails for $1900.
i was able to get an 08 pitch comp which retails for more than an xc pro for around $1300. you should be able to get it for $1400 or less
Since they completely changed the design for '09, AND '10's are starting to trickle out (making an '08 2 yrs old), I wouldn't pay anything close to $1600 for it. I just got a '09 XC Comp for around $1400.
'16 Specialized StumpJumper FSR Expert Carbon 650B
'09 Specialized FSRxc Comp
'05 Specialized Hardrock Sport Disc
Way too much money. I picked up a 08 Stumpjumper FSR Comp for $1560 back in September.
Thanks for the replies. I think I will hold out for a better deal. Perhaps I will look into a carryover Stumpy.
- You may not post replies
- You may not edit your posts
Forum Rules
