Results 1 to 5 of 5
    Distributor
    Reputation: carbonLORD's Avatar
    FYI Specialized uses 30 x 170 RaceFace cranks on the FatBoy
    I found out the hard way.
    carbonLORD /// KILOMETER
    Sep 2004
    Just getting around to looking at new cranks for the Fatboy. Very familiar with traditional spacing on MTB's but seems the Fatbike world is all over the place on spacing, etc. Can either the Turbine or Next SL cranks work? I also read it must be the cinch style crank? It looks like I need the 170/30 RF crank (Turbine preferred if possible due to cost), PF30 BB and maybe a spacer kit? any help is appreciated as it get expensive quick!
    Distributor
    I actually ended up keeping the 190 RF Next cranks because I'm a big guy and the Q-factor doesn't bother me, plus I like having the 36T ring and may go back to a 2 x 10 when I upgrade to XTR Di2 in February.
    That said, to answer your question, my cranks came with the spacer kit and are only needed with 190 cranks so you won't need it. Not sure if you "need" the cinch system but it's certainly not a bad system as you can swap parts out quickly.
    Quote Originally Posted by Supa8 View Post
    I'm planning to order the 170 Cinch cranks. If you flip the chainring you'll have enough clearance for the tires while keeping the narrowest q factor possible. (Confirmed by RaceFace).
    I have no idea what CarbonLord means by "the hard way".
    Distributor
    Quote Originally Posted by jester6578 View Post
    It means I bought 190's, extra spacers, a sleeve that didn't fit and could have just gone 170's to begin with.
  1. Replies: 4
    Last Post: 2 Weeks Ago, 05:50 PM
  2. Anyone excited on the new Raceface Next SL cranks?
    By fishcreek in forum Singlespeed
    Last Post: 10-30-2013, 10:10 PM
  3. CRC - RaceFace Atlas cranks
    By ozzybmx in forum Fat Bikes
    Last Post: 06-21-2013, 08:49 PM
  4. New RaceFace cranks?
    By hatake in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-19-2011, 12:03 PM
  5. Replies: 12
    Last Post: 08-28-2011, 08:19 PM
