    FSR geometry confusion
    I'm looking at buying a used '04 FSR Pro. The seller lists the geometry as:
    Seat Tube: C2C: 37.5cm
    Seat Tube: C2T: 46cm
    Top Tube: C2C: 56cm
    Stand Over Height: 71cm
    None of this seems to make sense. The seller hasn't replied to my questions yet, so any idea what size this bike probably is? I'm looking for a large and unless I'm confused, those numbers seem small.
    Here's a photo if it helps:
    Jan 2005
    It looks more like an S or in between, so I looked at the Specialized 04 PDF. From this I think this is a Women's version in M.
    The PDF specifies 56cm as the Top Tube length
    Standover heigth of 72cm (about the same as the Men's S).
    If you are looking for a large this is definitely not want you need because it looks even smaller dan a normal M.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    go to www.specialized.com and visit their archives section for 2004....that model looks like the fsr pro disc except the paint looks darker on the specialized site..the women's fsr for 2004 only came in fsr elite disc
    Attached Files Attached Files
