Results 1 to 7 of 7
Thread: Front Mechs.
    Jun 2005
    Front Mechs.
    Which front mechs will fit my Epic comp 05? XT and XTR. What do you recommend?
    I can not find that info anywere!
    Reputation: MTBerJim's Avatar
    May 2005
    Quote Originally Posted by erdu
    Am I the only one? I don't understand what the hell you're asking about, dude.
    Jim D.
    04 Stumpjumper Expert Disc
    10 Marin San Rafael
    Unit 91
    Reputation: TheProphet's Avatar
    May 2005
    Yea me neither dude, more info.
    Bikes
    Quote Originally Posted by MTBerJim
    Probably something like:
    clamp size?
    top/down pull?
    top/bottom swing?
    Just a guess...
    Down pull, top swing for the Epic
    Jackie
    May 2005
    Quote Originally Posted by Jackie
    clamp size?
    top/down pull?
    top/bottom swing?
    Just a guess...
    Jackie
    He did bother to reply, I guess it wasn't to important in the first place.
    Hey Jackie I hit you're profile button by mistake, where's cro?
    10 Marin San Rafael
    Reputation: Archangel's Avatar
    About Shimano FDs
    The old type XTR 952 doesn't fit very well into the Epic. The cage contacts the main suspension pivot when shifting to the granny ring. Also the cable clamping bolt is in weird place to fit into Specializeds (Enduro is even worse). I managed to fit that FD into my girlfriend's '03 Epic by filing off a bit of aluminum from the derailleur cage. The old XT 750 should fit better.
    The new XTR 960 and XT 760 fit fine although I never managed to get the XT 760 to shift well in that Epic (and that's why I changed it to the 952).
    XTR shifts better than XT and is more durable but also costs about twice compared to XT.
    Like the guys before me said, you will need a TS, DP derailleur with a 34.9mm clamp.
    Croatia
    Jackie
  1. VP-Free front mech setup question and answer.
    By robsetsfire in forum Santa Cruz
    Last Post: 06-23-2005, 09:56 AM
  2. front deraileur and compact double crank
    By rapid tourist in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-20-2004, 01:34 PM
  3. rattling noise from front deraileur
    By jakubc in forum Tooltime
    Last Post: 06-08-2004, 06:52 AM
