Results 1 to 3 of 3
    Fox tapered fork with Epic frame
    Does anyone know if the newer fox forks with tapered steerers (1 1/8"-1 1/2") will work in specialized (epic) frames with the tapered head tubes? Thanks.
    Feb 2006
    Since tapered is a standard, you should be okay. Honestly, though, don't take my word alone for it. I didn't even realize that Epics had tapered head tubes
    Reputation: mrilo's Avatar
    On my Epic comp 29er I swapped out the stock tapered Reba SL for a new 2010 tapered Fox F29 and it was fine. Just had to switch the crown race over to the new fork after cutting down to size the steerer tube and installing the star nut.
