    Fork steerer tube length
    Anyone know the fork steerer tube length for the 08 Epic s-works (large) ?
    Its not in the geometry on the website....
    Thanks,
    you won't likely find it. the steerer tube lenght will vary depending on the number of spacers, headset stack height and stem height. you can get an approx, by adding the head tube height info + headset + stem + # spacers + margin of error!!
    Quote Originally Posted by was98strat
    Right, but when the bike is manufactured and assembled surely all the steerer tubes for a particular make/model/size of a bike are cut to the same length ?
    I'm building up a frame and I'd just like to know what the factory build parameters are, so I've somewhere to start from...
    Large 146 mm headtube + 38 mm height stem aprox=184 + -
