Results 1 to 2 of 2
    Make some music
    Sep 2004
    Flip Flop Link - Enduro 130
    This link has an offset shock mount hole. Flip it and increase the bottom bracket height. The interesting thing is that on the side facing up of the lower hole seting is printing that says 13.3" bottom bracket. Flip the link to the higher hole setting and the top side has printing w/ 12.8" bb. (These are not the exact numbers, but I don't feel like going down the the garage to get the numbers. However, you get the point.) Do you see the question here?
    I'm guessing the printing for the applicable hole would be read from the underneath as it is mounted on the bike.
    J.O.R.B.A. More than just tm. WWW.JORBA.ORG
    Reputation: CSPRINGS's Avatar
    Strat,
    As pictured on your Enduro Pro frameset (with the bolt hole below a line drawn between the two pivot points) is the lower BB setting.
    70/71 USA sunburst sino tremolo here…I likey.
    C.SPRINGS
