Results 1 to 8 of 8
    Reputation: Not So Fast's Avatar
    First upgrade SJ 120
    I'd like to up grade some parts my '05 SJ 120. I ride xc, weigh 220 lbs. I like to do small drops 2-3 feet. I'm looking to lighten up the bike some. What upgrades would you recommend considering my weight.
    mechmann_mtb
    Guest
    XT cranks w/ external BB
    a good wheelset (i ride Mavic CrossMax XL and i am 205lbs) can lighten the ride.
    the stock tires are good and if you do drops and stuff you don't want to go much smaller than them, i ride 2.4" tires which are heavier.
    Reputation: Biker75's Avatar
    Quote Originally Posted by PingaMan
    Hey Pinga,
    in addition to the previous post, I'd recommend a carbon bar & Thomson post. My new seatpost was way lighter than my cut down old stock'er. I'm doing similar riding to you sounds like, and both are holding up great.
    JW
    Beer has food value. Food has no beer value.
    just like a speeder-bike
    Reputation: Barkdog's Avatar
    My 1st upgrade to my 120 Pro was Crank Bros Eggbeaters -- nice 'n light.
    Gravity Rides Everything
    Reputation: endurowanker's Avatar
    if you have the SJ 120 expert get rid of the garbage cranks.
    the spider loosened off mine after about 3 monthes. creak city.
    Feb 2005
    on my SJ pro
    I changed:
    Fork - replaced the minute with a Talas RLC (it rocks!)
    Brakes and shifters - returned the shimano integrated pieces of garbage and got xt rapid fire and juicy 7's. Also put a 7" rotor up front.
    Reputation: plussa's Avatar
    My '05 SJ 120 Expert has been upgraded with:
    • XT hollowtech II cranks/bb
    • T.A. Specialites chainrings
    • PD-M540 pedals
    • XC717 / XT wheelset
    • Nokian NBX 2.3 kevlar tyres
    • XT cassette
    • X.9 rear der., X9 triggers
    • S-Works carbon riser
    • Thomson setback seatpost & Thomson X4 stem
    • Selle SLR carbon/titanium 135g
    Weighs a lot less and looks nicer too...
    Current Specs
    Here are my specs. 05 EXPERT
    FRAME FSR technology, M4 Manipulated Alloy frame with Transform monocoque TT, sealed cartridge bearings, disc compatible, 120mm travel, replaceable derailleur hanger, two sets of water bottle bosses
    REAR SHOCK Fox Float Septune.
    FORK Fox Talas RL, 95-130mm travel,
    HEADSET 1 1/8” Threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt
    STEM 3D forged CNC machined, 4-bolt, 31.8mm OS clamp, 8 degree rise
    HANDLEBARS Specialized XC Low Rise 31.8mm OS bar, 2014 butted alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
    GRIPS Oury
    BRAKES Avid Juicy 7 hydraulic disc, 160mm,
    BRAKE LEVERS Avid Juicy 7 hydraulic disc
    FRONT DERAILLEUR Shimano M-570 LX,
    REAR DERAILLEUR Shimano M-952 XTR,
    SHIFT LEVERS Shimano M-570 LX
    CASSETTE Shimano XT
    CHAIN SRAM PC99
    CRANKSET Custom Shimano Hollowtech, Octalink XT Spline
    CHAINRINGS 32Ax22S, 4-bolt 104/64mm pattern, steel chainring bolts RaceFace bashguard
    BOTTOM BRACKET Shimano ES-30 Octalink spline, 68mm shell, 118mm spindle. 50mm chainline.
    PEDALS Shimano 520 SPD
    RIMS Front Mavic X317 disc, 26”, black, eyelets
    FRONT HUB Specialized Stout Disc, 32 hole
    REAR RIM and HUB Mavic Crossland
    SPOKES DT Swiss Competition, 1.8mm, SS, black, alloy nipples
    TIRES Specialized Adrenaline Pro 2.0, aramid bead, dual compound, 120tpi
    TUBES yes
    SADDLE Specialized BG technology, hollow Cr-Mo rails, dual density base
    SEAT POST 2014 butted Alloy, black, 30.9 x 350/400mm
    SEAT BINDER Alloy collar with Q/R, 34.9mm clamp I.D., black
