Results 1 to 8 of 8
    Extra wheelset for my S-Works 29
    I want an extra wheel set for my 2013 S-Works Epic.
    I assume that any front wheel with 100 mm hub and 9 mm thru bolt or 5 mm QR will fit.
    But what are the options for the rear wheel if I want to stick with the 142+ hub and not adjust gear wire and derailleur each time I shall swap the wheel?
    Alternatively I can build the wheel myself. But where do I find a high quality rear 142+ hub? The crappy HiLo 142+ is no option.
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I wanted an extra wheelset for my SJ, so I searched around and found a damaged Roval 142+ rear wheel that had the DT240 hub. It's pretty much the only way to get a 142+ rear hub. With a standard 142 hub you have to adjust the RD every time you swap wheels.
    14 Aurum, 16 Fuse, 17 T130
    old fart
    Quote Originally Posted by ErikGBL View Post
    I wouldn't worry too much about the 142+ factor. I have found it to be inconsequential. I have also found that it is a good idea to have an additional wheelset that you can use for different conditions.
    I have commissioned a Easton Haven wheelset for winter riding (Hans Dampf on the rear Ground Control on the front). Due to the wider rim It can mount a wider, fuller volume tyre than my Roval SL's and the wheelset is still reasonably light at just under 1800gms. Foolproof UST with no requirement for rim strips was a clincher (as was the price). Longevity unknown but they are virtually silent - quite a difference over the Roval's.
    As for the 2mm shift of the rear chainline - I compensate with a few tuns of the shift adjuster - takes about 20 seconds.
    You are probably right, skiwi, I should relax about the "+" and use a 142 wheel set. The best of all is that I then already have the wheel set I need because I have built a 29er wheel set on DT Swiss 240s hubs which can be converted to 142 XX1. That is of course a little more effort than 2 second of wire adjustment but easier than change tubeless tires. I put the home built tires on my Chinese hard tail. It is best wheel set I have tried. I used LB wide rims and Pillar spokes. With the wide rim I can run them tubeless with a pressure as low 20 psi with Racing Ralph 2.25 even if my weight is 92 kg plus gear. With this low pressure they run so smooth on the trails that I can use a rigid fork (for rough conditions I use the Epic).
    I will probably build another set of these wheels.
    old fart
    The new trend towards larger volume tyres is something that happened in 26er land a few years back - I am personally comfortable with rims around the 21mm internal width to mount tyres up to 2.4 - and they do make a nice difference to the handling of the bike.
    Both the Roval SL's and the Haven's are 21mm - I am building a set of Stan's Arch for winter plugging - these are 19mm internal but for a true mud tyre you don't want width as much as vertical grip so these should be ideal. Both the Haven's and the Stan's are 142 obviously.
    +1 for the Ron's - I have a 2.25 Ron on the front of my Roval wheelset. Love it.
    I have a set of hardly used hubs and the straight pull spokes off 2012 s works rovals. The rear hub has ceramic hybrid bearings and the spokes are the 2012 ones with the mix of DT black revs and red aerolites. I wanted to change wheel sets easily so had to go with normal hubs. I'm in the UK if its of interest
    Moda, I have sent a personal message to you about your hubs.
    Erik
    I cant see that i have any message, can you resend..
  1. Replies: 0
    Last Post: 03-19-2013, 09:58 AM
  2. getting a new wheelset for S-Works Enduro
    By ashas in forum Wheels and Tires
    Last Post: 12-05-2012, 06:35 AM
  3. A little something extra
    By ArkansasOutside in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 08-29-2012, 10:56 AM
  4. Extra wheelset or just swap tires?
    By xceebeex in forum Wheels and Tires
    Last Post: 08-03-2012, 05:04 PM
  5. extra wheelset for 29er
    By donn12 in forum 29er Components
    Last Post: 07-16-2012, 07:13 PM
