Results 1 to 11 of 11
    Epic vs Epic Marathon
    What is the differnce between the 2?
    To me, it looks like the same bike with different components...or am I missing something?
    Reputation: Jacobus's Avatar
    Yes, componets. This is the first level of bike that has the new Specialized Shock.
    REAR SHOCK Specialized AFR Shock w/ Flow Control valve, adjustable from HT firm to Trail Tune, air spring, adjustable rebound
    FORK Fox F100RLC, 100mm travel, air spring, alloy steerer
    HANDLEBARS SBC OS XC low rise carbon bar, 640mm wide, 6 degree up, 8 degree backsweep
    FRONT BRAKE Magura Marta, hydraulic disc, S/M 160mm rotor, L/XL 180mm rotor
    REAR BRAKE Magura Marta, hydraulic disc, 160mm rotor
    BRAKE LEVERS Magura Marta
    REAR DERAILLEUR SRAM X.0, 9-speed, long cage
    SHIFT LEVERS SRAM X.0, carbon/aluminum trigger 9-speed
    RIMS Mavic XM-819 Disc, black, welded seam, tubeless
    FRONT HUB Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
    REAR HUB DT Swiss Custom SL, 32h disc, alloy QR
    FRONT TIRE Specialized Fast Trak Pro 26x2.0", tubeless, aramid bead, dual compound
    REAR TIRE Specialized Fast Trak Pro 26x2.0", tubeless, aramid bead, dual compound
    TUBES N/A
    SADDLE Specialized BG Rival, Titanium rails
    SEAT POST Thomson, 7000 series aluminum, 2-bolt adjust, set back head, 30.9mm x 367/410mm
    The Other Dude
    Reputation: jut8's Avatar
    if you can, go for the marathon, its a great bike, with great components, especially for the money.
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
    Quote Originally Posted by jut8
    I was originally interested in the SWorks carbon Epic. But then I saw the carbon Marathon Epic in the catalog and it looks like a much better value...and has a few parts that I like better than the SWorks.
    To throw another wrench into it...the shop has a 07 Epic Expert with about a hour on it that I can get for well below cost.
    So now I'm stumped as to what to get.
    The Other Dude
    that new shock is REALLY nice, and the RLC fork on the marathon is well worth the extra $$.......the carbon marathon is probably the value as you already stated.
    Ditto
    Feb 2007
    There is one difference in the frames between the two, the marathon uses a carbon shock link where as the standard Epic to the Expert use a hollow alloy shock link. This is the only major frame difference and the components do get better as you go up line.
    If it helps your decision, I am picking up my 2007 Marathon Epic tomorrow.
    Quote Originally Posted by Jacobus
    no...that really doesn't help at all
    Sorry.
    Now it only needs some dirt on it.
