Results 1 to 30 of 30
Thread: this epic skips
    Devo
    Reputation: SelfPropelledDevo's Avatar
    this epic skips
    This Epic skips gears.
    its my buddy's bike, and I cant figure it out.
    I've replaced the entire drive train
    new chain
    new cogset
    new chainrings
    straightened the rear derailleur hanger with a park derailleur alignment gauge
    its got XO shifters and derailleur
    new cables and housing
    the rear housing is all one piece, zip tied into position with enough slack in the loops to let the cable/housing move when needed.
    it most notably skips when in the middle ring
    mid cogset
    under pressure
    sometimes it ghost shifts immediately after he lets up on pedal pressure.
    any ideas?
    I need to get this bike fixed.
    sometimes I think there is something flexing that causes the derailleur to make it shift.
    sometimes I think there is something cracked, and the rear end flexes around
    but I can't find anything
    and it doesn't make any creaking sounds.
    sometimes I wonder if it has something to do with the suspension movement
    i.e. pedaling up a rocky section when the suspension is working...
    www.AsanaCycles.com
    "Bicycle Lifestyle, realized." D.G.
    Reputation: dkbikes4life's Avatar
    If you think the suspension movement may be causing it, let most of the air out of the rear shock so you can cycle the suspension by hand and look to see if the rear derailleur is moving.
    Devo
    Quote Originally Posted by dkbikes4life
    good idea!
    www.AsanaCycles.com
    Reputation: Jacobus's Avatar
    Step number 5 click here
    Devo
    Quote Originally Posted by Jacobus
    another great idea!
    this bike keeps eating up time
    www.AsanaCycles.com
    is the cassette tight? is the freehub loose? (bearings or bushings worn, i have seen this on old Mavic hubs where the bushing is all worn out)
    hard to diagnose from a keyboard though. :/
    Try to be good.
    Devo
    well, dam
    I can't get this bike to quit skipping.
    I even changed the rear derailleur
    everything is squared away.
    what I notice is that there is a bunch of flex between the BB/rear triangle
    I'm thinking about measuring the flex...
    maybe a video?
    www.AsanaCycles.com
    \m/ \m/
    Reputation: Blade-Runner's Avatar
    Nov 2007
    Sounds like the the derailleur cable might be too short or routed wrong......
    13' Lynskey M290
    13' Venge Pro Force
    13' Crux Elite
    12' Co-Motion Speedster Tandem
    Reputation: bwalton's Avatar
    Maybe your free hub is worn out. Either the paws or the inside spline that the paws ratchet up against may be worn out. For example, my OEM Shimano free hubs normally last for about one year before they start to skip randomly. If your Epic has a Deore RH-M525 hub like most Specialized Mountain bikes have, then you probably need to replace the free hub body. Before you or LBS installs it, pull the seal off the back and drip about 5 to 10 drops of 30 or 50 weight motor oil in it and re-install the seal. The added oil will insure that the paws are well lubricated so they donít wear out prematurely. Also drip oil into the back of the free hub every time you rebuild/repack your hub bearings with grease.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Does the housing routed under the bottom bracket have enough slack to account for suspension movement?
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Reputation: zippy895's Avatar
    Quote Originally Posted by Berkley
    x2.
    Devo
    I just fixed it!
    loose derailleur hanger.
    the #30 torx bolt was about 1/2 turn loose.
    this thing has driven me crazy
    www.AsanaCycles.com
    Glad you got it fixed. Its normally the small stuff. Although you said the rear of the bike is flexing a lot. Is there something wrong there still?
    Oct 2007
    Thought the same thing when I read it! Maybe the bearings for the suspenion need to be replaced???
    Glad to hear you fixed it!
    Chris
    Devo
    this bike has been a very interesting exercise
    this is a buddy's bike
    I have no idea how long he has had it
    every time I had ever been around him while he was riding it, it always skipped, popped, banged, etc...
    I started working on it, and initially I figured it just needed a new drivetrain, and straighten the derailleur hanger... typical stuff.
    so I do the work and go thru the entire bike, noting a handful of things...
    I ride the bike around and it runs fine.
    we go for a ride, and bang! pop! it jumps, and skips.
    I can't stand it.
    I get the bike back the other day, and start into it.
    as a last ditch effort I started this thread.
    I can recall in 90's often times a bike may shift under load, I'm thinking a bike like a Pro-Flex or something, and it had me thinking that maybe there was something to do with the Brain setup, inertia valve, stable platform valve, suspension set up, etc...
    I kept wondering if the bike was cracked.
    I've seen road bikes shift under load, because of a cracked bb shell, etc...
    I re-work all sorts of stuff on this bike. Its pathetic.
    just for the heck of it, I pull out a Torx bit, and sure enough... the freaking bolt turns!
    I could hardly believe it.
    the rear derailleur hanger was tight, when I'd check it my bare hand, but obviously it was moving when putting pressure to the pedals.
    weird enough, I'd ride the bike, and apply the rear brake, the ghost shifting was minimized.
    applying the front brake only and putting pressure to the pedals, made it skip...
    after tightening the #30 (I'm pretty sure its a #30) Torx, its solid. no skipping, shifts up and down under pressure, etc...
    I think this has been an issue with this bike for at least a year.
    my buddy kept telling me these stories of shop wrenches telling him that it was the way he was riding. that its his fault for the way the bike was performing. As if he wasn't riding the bike correctly.
    ok... I can see that comment coming out. But really, its a freaking inanimate object. Its a tool. Its a bike. It should perform under all those less than optimal driving techniques.
    of course, its not that great of an idea to cross chain, etc...
    but the reality is that people do it all the time...
    needless to say, I'm glad to have solved this issue with the bike.
    www.AsanaCycles.com
    Now broadcasting from CO
    Reputation: PAmtbiker's Avatar
    Feb 2005
    It's funny how the simplest thing can cause a world of problems.
    Now all you have to do is pull that bolt off and Loctite the bejesus out of it... make sure it's not going anywhere!
    Brought to you by rocks.
    Devo
    this bike has started to skip again...
    I'm looking for a torque spec on this #30 Torx bolt.
    any ideas where I can find that?
    thanks
    d-
    www.AsanaCycles.com
    Try taking a link out of the chain?
    Gravity's Gone
    Reputation: nankerphelge's Avatar
    Have you tried a different rear skewer? I've seen bent and or worn ones cause these types of problems.
    Devo
    I wrenched on this bike for buddy and it took forever to figure this issue out.
    it came down to that #30 Torx bolt being loose
    he is thinking about buying a new derailleur hanger and bolt
    I want it to torque it down to spec
    I think its crazy that this is a recurring issue.
    www.AsanaCycles.com
    Feb 2005
    Quote Originally Posted by SelfPropelledDevo
    That would probably be the best idea. I've never seen a torque spec on hanger bolts, but I would ask your LBS. You could always Loctite it on there so it doesn't loosen as easily
    Reputation: JefedelosJefes's Avatar
    Don't ever bend a derailleur hanger back as a permanent solution. That is a great way to get home if you bash it on a ride, but every time it bends it gets weaker. Then it will just keep getting easier and easier to get ****ed up. Derailleur hangers are meant to be expendable, they are supposed to be the weak point to protect your frame (those specialized hangers are especially weak, i have to replace mine every other month or so). Loctite is always a good idea, and just snug it up good and tight, don't worry about torque spec, you will probably want higher than specialized officially specs anyways.
    Devo
    I'm so busy these days its amazing.
    this bike is going to fall into a work flow, hopefully sooner than later.
    I've got Dealer Days for Sea Otter that I'm heading up
    just finished a training camp
    got another gig coming up
    and an invite with a US Continental Pro team to wrench and see how things work out...
    busy is good!
    www.AsanaCycles.com
    Devo
    Quote Originally Posted by JefedelosJefes
    this is just "alignment". Not re-bending a totally destroyed hanger. using park derailleur alignment gauge.
    www.AsanaCycles.com
    Devo
    so I worked on this bike again today.
    my buddy has replaced the hanger with a new one.
    the interesting thing about the situation is that it seems as tho the actual rear dropout casting is deformed.
    that is to say, it seems as tho the casting is not "square"
    the new derailleur hanger has a nice perfectly flat top edge, whereas the receiving side of the dropout, is no longer "square"
    with a new Torx #30 bolt, and new hanger, it is still susceptible to movement.
    it seems as tho the appropriate fix would be to replace that section of the rear triangle, as if it were the seatstay.
    today's ghetto remedy was to use some disc brake shims, sandwich them between the hanger and the dropout, with the tang of the shim extending outward between the hanger and the dropout, thereby allowing the shims to compress into position, effectively creating a crush seal between the two surfaces.
    I hate it. Its not correct.
    the interesting thing is; here is a bike that is obviously a fundamental component of the success of the company, which has suffered a short coming thru design.
    perplexed in that being a MTB and being beat thru use, the simple shoulder in the dropout casting which holds the hanger in place... seems to beg for a different design, as if a more secure mating match.
    as ghetto as this sounds, we were half inclined to simply JB weld the pieces together, and bolt the whole assembly down, which would squish JB Weld into the gap between the two.
    but I'm thinking that the movement of the two pieces will simply crush & crack JB weld.
    so we stuck to the shim approach, which in itself is not the best idea, but at least its not as permanent as JB Weld. the shims will simply come out of position when we take it apart again.
    it seems as tho the dropout is malleable. To the extent that the derailleur hanger is actually harder, and when it receives an impact, bends the hanger, etc... the force goes into the cast dropout, which is softer than the hanger.
    I have no idea how many times this bike has incurred these type of impacts.
    enough to deform the dropout.
    I guess my real question is: "Is this gap between the dropout and derailleur hanger normal? Or is the fit supposed to be flush?"
    I would think it should be flush.
    www.AsanaCycles.com
    West Chester, PA
    The hanger screw doesn't really do anything except keep the hanger in place when you take the wheel off. If the skewer was tight the whole time that was never the issue. Anyway, if you try to tighten it too much it will break, its aluminum.
    Have you taken the frame apart and checked the bearings at the bottom bracket/chainstay pivot ? Those bearings constantly have dirt and water thrown on them. On my prior specializeds they were good for about a year. If they are original on that bike they may be disintegrated to rusty globs causing a lot of play.
    Big Gulps, Alright!
    Quote Originally Posted by 92gli
    +1. Those bearings are tiny and get toasted pretty fast.
    Devo
    the hanger screw isn't the big issue.
    its the gap between the dropout and the hanger.
    or rather, its the hanger than moves due to the gap.
    its crazy.
    if the hanger can manage to stay put, the bike is good to go.
    as soon as the assembly comes loose, the bike will ghost shift.
    the hanger vs dropout
    not only has that nice square edge
    but also, they have a slant which they mate to.
    so you tighten everything down.
    place the wheel into the dropout with the hanger bottomed out against the dropout.
    (gap closed as much as possible)
    at some point... typically about a week...
    the bike starts to ghost shift
    inspect bike... the #30 TORX bolt is now loose about 1/2 turn.
    which translates to the hanger is moving around under torque.
    looking at the dropout... the shelf which the hanger would mate too... you'll notice is not straight
    plus the hanger does not have a snug fit. there is a gap all the way around the hanger.
    it seems that no matter what... this assembly works its way loose.
    www.AsanaCycles.com
    it would void all warranty possibilities, but you could probably prep the surface and fill that gap with JB Weld. certainly this bike has been around the block and is due for replacement.
    Try to be good.
