Results 1 to 5 of 5
    MDL
    MDL is offline
    Feb 2007
    Epic S-Works rear brake rotor.
    On the S-Works Epic 2007 the rear rotor is a 140 mm. Is it possible to increase the rotor size to 160 mm.
    The Other Dude
    Reputation: jut8's Avatar
    Yes you can, but you must buy a new 160mm rear caliper, it works the same way my martas do. it so much easier with the juicys...just buy a new adapter and new rotor.
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
    MDL
    MDL is offline
    Feb 2007
    Thanks jut8.
    He just needs the rotor and adapter, not a new caliper.
    The Other Dude
    i thought on the 07 XTR stuff the mount was built into the caliper as the martas are, atleast that is the way the have appeared to me.
