    epic rear suspension?
    can someone give me the details about how it works? and also does it stay stiff if you do a little 2 ft jump? how about a bigger jump?
    so you can adjust it to be fully plush?
    the epic rear suspension gives a stiffer ride to minimise bob and give you maximum efficency and manoverability, you can adjust the shock to be plush and set the brain to soft so it stays active and goes through most of its 100mm travel, the ride will still be stiffer than say an xc, i have both bikes, an 07 xc comp and an 08 epic comp, if you take a jump the epic shock will kick in but its not exactly a jumping bike, i do feel however that its under rated in some respects, it does everything better than my xc and that includes bombing downhill, its a brilliant bike
