Hi,
I have an Epic S-Works '05 with a Float-R with Brain
During maintenance I've opened the shock, cleaned it and filled it with new oil (2cc of fload fluid).
So far so good, now I also opened the top cap of the brain to inspect it, some air and oil came out!
After closing the cab and putting pressure (80 Psi) on the shock, the shock lost its auto lock-out, also the SAG is bigger than before now more than 50% of the full travel, with same air pre load than before.
Now I don't see how to put back pressure (and how much) into the brain's top compartment.
Can anyone tell me how to do it, what oil to use and how much?
Is there a description somewhere available for the correct maintenance of the Brain itself?
Thanks,
Stijn
Thanks,
Stijn
