Results 1 to 5 of 5
    Epic Expert Carbon 29er weight?
    Does anyone know the weight of the stock XL Epic Expert Carbon 29er?
    Thanks for your help!
    Aug 2013
    well i found a page that weighed alll the 2013 epics except the carbon expert, but they did wheigh the expert evo and i canīt imagine there should be any weight difference between the Epic expert carbon and the evo
    so the epxert evo wieghs 23lbs/10.40kilograms
    regards
    pekka
    Feb 2012
    Quote Originally Posted by PekkaS-works View Post
    regards
    pekka
    If you are talking about the 2013 Expert EVO R vs 2013 Expert, the frames are different. The EVO R has the same carbon 10m and carbon seat stays as the marathon vs the expert's 9m and alloy seat stay. I pretty sure I read the marathon frame was 200g lighter than the expert, but I could have made that up
    Also the EVO R is 1x10 and carbon bars, so I'd guess the expert is 1lb - 2lbs heavier.
    That's what I'm thinking. An XL Expert has to be at least 25lbs...
    Thanks for your help.
    Reputation: AZ Stumpy's Avatar
    Nov 2008
    I rented a 2013 Epic Expert XL a few weeks ago. It was 26 lbs on the nut but had slime tubes. I was guessing it would be just under 25 lbs setup tubeless.
  1. 2012 Epic Expert Carbon 29er weight
    By Juza72 in forum Specialized
    Last Post: 05-18-2013, 03:21 AM
  2. Epic Expert Carbon 29er vs Expert Evo R 29er
    By barry1me in forum Specialized
    Last Post: 05-07-2013, 01:08 PM
  3. 2011 Epic Carbon Expert 29er or Epic S-works 29er?
    By crimecrusher in forum Specialized
    Last Post: 05-13-2012, 10:42 PM
  4. Replies: 5
    Last Post: 02-25-2012, 02:49 AM
  5. 2011 Epic Expert Carbon Wheelset Weight?
    By mgsuarez in forum Specialized
    Last Post: 01-05-2012, 06:37 PM
