Results 1 to 45 of 45
    rider
    Reputation: Swami Scott's Avatar
    Epic Expert 29 - picked it up today
    My order came in fast so here it is. I'm not a fan of the white seat, grips and stem so the shop swapped 2 out of 3 for me. 26.25 in size large, right out of the box.
    I hadn't noticed the newer spec with the S-Works tires on it. The Renegade looks pretty racey and might be off and on classified soon.
    Ben-Jammin
    Reputation: CasteelG's Avatar
    Nice! It looks much better with less white bits.
    Be prepared to replace the S-Works tires though.
    I split the sidewall on my Captain on the first ride. The Renegade is holding up pretty well, and is actually pretty grippy, but it's just a matter of time before a sharp rock kills the sidewall.
    Reputation: goneskiian's Avatar
    Sep 2004
    Very nice!
    I have the S-Works Captain on my Marathon 29er from this last year and it's holding up well. I have a friend that has had a 2011 Stumpjumper 29 Comp for a month or so that came with the S-Works Renegades and he's already got a cut in the sidewall that's a good 3/4 of an inch long. In their defense though it looked to me more like a box knife slice rather than rock or root damage.
    Cheers!
    rider
    Quote Originally Posted by CasteelG
    Thanks. I'm not a fan of the white so off it went. Next off is the stem and the red decals on the wheels.
    I think I'm going to peel them off while they're unused and sell them, No sense ripping a sidewall, first ride, on a $60 tire.
    Ben-Jammin
    Quote Originally Posted by Swami Scott
    Good idea. I thought the sidewalls wouldn't be an issue for me since I'm light and float over rather than plow through things, but I was wrong.
    What are you thinking of replacing them with?
    lord of my world
    Reputation: surlywhore's Avatar
    Dec 2005
    Very nice! I am waiting on a Stumpjumper HT 29er Carbon Expert!
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    nice to see some bikes ship
    still waiting for my frame, roval wheels and 2011 fox fork
    p.s. looks like your brake spacers are in the wrong order on the back of the bike
    I am slow therefore I am
    rider
    Well, not sure. I have plenty of non tubeless options laying around. Of course not as light as what's on the bike! Might look at some Bonty offerings or the Control versions of the Captain and the Fast Traks
    Quote Originally Posted by SlowerJoe
    Can you elaborate so I can check it out?
    Sup
    Dec 2008
    the silver spacer on the bottom is part of the concave spacer under the caliper
    if you zoom in on your bike on the site you can see there is nothing under the black spacer
    sadly, like the element
    Sep 2004
    It's that way from Specialized it seems. I picked up the same bike and the rear spacers are set the same way. Guess I get to pull it apart when I can get the tubeless set up.
    Sup
    Dec 2008
    cool bike
    give us an update once you get some miles down
    The Other Dude
    Reputation: jut8's Avatar
    looking good for sure! Awesome bike you have there!
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
    Sep 2004
    I can't seem to get the tubeless to work. Went and purchased two of the normal Captain control 29x2.0 2bliss tires. They'll mount and air up with a compressor nearly instantly, but they leak like mad from the eyelets and the valve stem. The Caffelatex I put in was just a foamy mess coming out everywhere after I shook the wheel around at ~25psi.
    I'll leave the rear tire mounted with latex in it overnight and see what happens. But the front tire I've dismounted and given up on for now. Clearly I'm meant to suffer the slings and arrows of outrageous fortune (goat heads) than actually be able to ride more than 3 miles around here.
    Also, the rear caliper is actually assembled correctly. The black spacer is concave near the rear brake and the silver washer near the frame is flat on both sides.
    Ben-Jammin
    Quote Originally Posted by Leadghost
    Did you check the factory tape job? The tape in the rims on my bike didn't cover about a quarter of the eyelets on either wheel...
    Once I re-taped them with two layers of electrical tape (One layer closer the right side of the rim and one layer closer to left. Stretched tightly with little to no air bubbles.) the leaking stopped and I haven't had any issues since.
    Sep 2004
    I'll have to try that. As far as airing them up, do you go up to 35+ psi right off the bat?
    Sep 2004
    I had to redo the tape on my Roval wheels too. I stripped off the blue tape that came on them, cleaned them well and used some Stans yellow tape. No leaks now!
    Sup
    Dec 2008
    guess I was wrong again
    West Chester, PA
    Electrical tape is not a good idea if you want the rims to stay sealed. It will work its way off due to heat and/or sealant getting it wet.
    Why don't any shops adjust the hose angle on the calipers ? Just a pet peeve that is driving me crazy lately. Laziness, pure laziness. Takes 5 seconds for each end.
    Ben-Jammin
    Quote Originally Posted by 92gli
    I've had rims that have been taped with electrical tape for years and haven't had any issues.
    West Chester, PA
    Must be magic because every time I've stretched electrical tape the gooey adheasive slips and it loosens. And its not even close to moisture resistant.
    Ben-Jammin
    You must be using cheap tape then, because as I said, I've NEVER had issues with it.
    rider
    I was thinking that myself and I've stared at the funky angle again and again! I'll fix that when I throw my set of XX's on.
    Trail Rider
    Reputation: mlx john's Avatar
    I had to retape my wheels. They came with the blue spec. tape, but whoever/whatever did a terrible job installing the tape. Just picked up a roll of the blue tape and did it myself. You need two layers of tape per wheel (two revolutions of wheel while taping).
    Sweet bike.
    What does that set of wheels weigh? Heard they are on the heavy side.
    Great looking bike.
    Sep 2004
    Quote Originally Posted by mlx john
    Sweet bike.
    My tape seems to be covering the holes, but it's just not wide enough I think to adequately seal the spoke holes completely. At <20psi the tire is inflated and nothing is leaking, but once I pump it up to ~30psi or so, it just starts leaking from at least 50% of the spoke nipples and the valve core and sealant cannot keep it sealed.
    I have some of Stan's yellow 21mm wide tape on order per this thread on Notubes.com. I'll try just taping over the blue with the Stan's and report back.
    Sep 2004
    Yup, the 21mm wide yellow tape is the ticket. 2.5hr ride with some small drops and no leaks or burps. Ditch the stock blue tape if you're going to go tubeless.
    Using a pair of the normal Captain 2bliss tires, sealed up instantly with no leaks outside of the Spesh valve which sealed quickly after some sloshing
    May 2010
    what is the difference between the expert carbon 29, and the carbon comp 29? was all set on the comp carbon after considering the tallboy and the anthem 29, but all the talk about the expert carbon is making me confused. it's about 800 bucks more, frame and shocks are the same, what the main difference?
    what the tire clearance on these bikes like, and will a 20mm rim cause troubbles for wider tires, say 2,25 at least.
    thank for your help guys!
    Reputation: farmertan's Avatar
    Is that 26.25 pounds without the pedals, or with?
    very nice, can't wait to get mine
    S-Works all the bikes!
    Just another used cat for sale
    rider
    @farmertan - That was without pedals. I'm a bit under 26 lbs. now with pedals after making a few parts changes. More parts changes in store. Unfortunately, I'm second guessing myself on whether I should have just bought the S-works frame and built up now that I've swapped so much out.
    @knutsand - Fork is not the same as the Comp. Also different is the crank, rear der., shifters, bottom bracket.
    Reputation: rmasse10's Avatar
    Aug 2010
    Definitely a very sweet ride!
    Custom Performance Apparel for the Trails
    Surfmonkey Gear
    Sep 2004
    Yeah, but you'd still be waiting for a bike if you'd done that!
    Who says patience is a virtue?
    May 2010
    what did u change to get it under 26, approx how much did it cost u
    rider
    @goneskiian - So true! Not sure how far out those Sworks frames are. I have little patience and I've been known to make spontaneous purchases so now I have this nice bike (along with way to many others that now need to get sold). I need to stop thinking about should of, could of, and just enjoy it.
    @knutsand - right off the bat I changed seat, seat post and cassette. I added pedals and it was 25.9 at that point. Of course I didn't stop there and now it's XX shifter, brakes, front der..
    Freedom Isn't Free
    Reputation: A-Hol's Avatar
    Dec 2005
    [QUOTE=Swami Scott]@goneskiian - So true! Not sure how far out those Sworks frames are. I have little patience and I've been known to make spontaneous purchases so now I have this nice bike (along with way to many others that now need to get sold). I need to stop thinking about should of, could of, and just enjoy it.
    Yep, still waiting on my S-Works 29er frame and carbon wheels. Fingers crossed for Oct delivery.
    Sep 2004
    Quote Originally Posted by A-Hol
    You can cross your fingers, just don't hold your breath!
    I think Deuce9er said he was told Epic S-works frames weren't expected until the new year. Complete bikes in October.
    Sup
    Dec 2008
    you know goneskiian that kind of talk is not going to cheer any of us up waiting for our bikes
    Im just worried that the carbon wheels I ordered will be like some of the other products my bike shop ordered last year and they never make it across the continental divide
    I ordered the 142 kit for my heavy I9's just in case
    Rear tire clearance?
    What is the rear tire clearance on this? I'm leaning towards building up a Stans Arch wheelset on an Epic frame, and my typical go-to tires for routine riding are Ignitors. Any reason to think that they wouldn't fit?
    Sep 2004
    Nope.
    Swami, what's your take on the 142+ rear hub? Engagement good? Clicks or no clicks?
    rider
    Quote Originally Posted by CHSAD
    I am now a huge fan of 142x12mm! It's stiff and it lines up so well on wheel removals. I'm pretty much a Clyde these days so what a great, stiff setup for me. Decent on engagement, quiet like Shimano but I also run King's, Hope's and DT 240's on other bikes so no comparison to the Hope's and King's on both noise and engagement. I have to admit I'm a bit disappointed that the stock wheels are a little porky. I bought the bike whole which I'm STILL second guessing since I always build from the ground up. Now I'm about to toss the wheels too!
    rider
    Quote Originally Posted by TurnerConvert
    Easily! I haven't measured but looks to be a good bit of clearance.
    Are you happy with the hubs or do you think they are significantly inferior to say a DT Swiss? I don't know much about Specialized hubs - do they have a good track record for reliability?
    Sep 2004
    I believe the Specialized hubs use DT Swiss internals. At least the higher end ones do. On the rear anyway.
    I got the upgraded star ratchet for my Roval EL 29's that came on my Epic Marathon 29. Works great and is super easy to install.
    Cheers!
    Quote Originally Posted by goneskiian
    Cheers!
    Excellent info - thanks.
  1. Replies: 11
    Last Post: 09-07-2010, 04:05 PM
  2. Picked It Up! 2010 Stumpy FSR Expert 29er
    By Intencity in forum 29er Bikes
    Last Post: 02-11-2010, 07:00 PM
  3. Replies: 40
    Last Post: 05-17-2009, 08:54 AM
  4. Picked up a 07 Stumpjumper Expert.
    By z71 in forum Specialized
    Last Post: 03-17-2007, 11:24 AM
  5. Picked up an IH SGS FR expert for Diablo
    By robertg in forum New York - New Jersey
    Last Post: 08-02-2005, 03:58 PM
