Results 1 to 7 of 7
    Epic Comp 29 Stem Length
    So I'm looking to change out my stem on my 2012 Epic Comp 29 from the standard 105mm length stem to something shorter due to the fact that I rarely race and mostly use the Epic for general trail riding and I'm looking to make the bike more ergonomically friendly on my back/neck. Has anyone had any experiences with shorter stems/longer handle bars on an Epic? I'm 6'1 and ride a Large frame. I'm thinking a 70mm stem with a 720mm 3/4 riser handlebar.
    Oct 2012
    I would start out with a 90mm first, a 70mm seems like a big jump from stock.
    Im running a 70mm on stumpy fsr xl frame. Stock was a 90mm. I noticed a big improvement in handling. Uphill switchbacks are easier, and on the downhills the bike seems more responsive. As for climbs I didnt notice much in that department besides I have to move little more forward on the bars.
    I just called my LBS and they have a bunch of different stems I can test before buying one. What length are you running on your handlebar with the 70mm stem?
    Oct 2012
    720mm stock specialized bars, all mountain low rise.
    Oct 2012
    I would highly recommend an syntance stem after you test several different stems out. They are super stiff, light, and come with TI bolts along with a 10 year warranty.
    Thanks for the recommendation, I'll look them up.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    105mm is way WAY long for that kind of bike. 720 bars are kind of on the small side. I'd highly recommend going 800mm bars with a 70mm MAX stem. You'll find the reach similar, but less twichy and you'll be more in control.
  1. How does stem length and frame length affect handling
    By Fargo1 in forum Beginner's Corner
    Last Post: 10-31-2012, 07:23 AM
  2. Length of stock stem for Carve Comp
    By 29Spec in forum Specialized
    Last Post: 07-13-2012, 10:38 PM
  3. Epic 29er Stem Length
    By mgsuarez in forum Specialized
    Last Post: 09-16-2011, 07:25 PM
  4. Replies: 0
    Last Post: 08-24-2011, 11:08 AM
  5. 2011 Epic comp 29 or Stumpy HT comp 29?
    By Jblodge in forum Specialized
    Last Post: 02-11-2011, 11:33 PM
