Results 1 to 6 of 6
    Aug 2013
    Epic 2014 with Rockshox Rebe RL 29 - looking for other 15mm axle options than Maxle?
    Hi,
    I just bought a 2014 Epic Camp Carbon, with a Reba RL 29 with 15mm axle.
    The stock Maxle lite axle is a really flimsy piece of hardware, and I am looking for any other axle options, that will fit the Reba RL 29.
    Is there anything suitable on the market? I kind of like the DT Swiss RWS for the rear axle, is there a RWS available for the Reba?
    Christian
    Quote Originally Posted by Cjvje View Post
    Hi,
    Christian
    I had the same concern with my RS SID. I think they are proprietary so there may not be any aftermarket options. I'm not 100% sure of this but I was looking for the same thing.
    MCH Co-Captain
    Feb 2014
    Hi,
    Christian
    I actually broke off part of my stock Maxel. And I was having issues with the front hub having slack in it, even with the Maxel at full tension.
    The solution? The Maxel from the RockShox Pike is a direct fit for the Reba forks! This Maxel is a much better design and puts some side load on the front hub like a standard quick release dose. See if you can get your LBS to order one of the new Pike Maxels for ya.
    Fat-tired Roadie
    Nov 2007
    Been wondering the same thing. Thanks for posting.
    Reputation: bigkat273's Avatar
    Also the revelation uses the regular maxle. Not quite as cored out as the light version.
    Here is the thing about equality, everyone's equal when they're dead. - Gavroche, Les Misérables
  1. Replies: 8
    Last Post: 01-09-2017, 09:14 PM
  2. Replies: 0
    Last Post: 03-08-2014, 02:38 PM
  3. Stan's 3.30 15mm Hub/Rockshox axle and fork compatibilty
    By rustyjacksons in forum Wheels and Tires
    Last Post: 02-09-2014, 03:11 PM
  4. Yay! 160mm Rockshox Pike. Booo! 15mm Axle.
    By juan_speeder in forum 29er Bikes
    Last Post: 04-04-2013, 03:30 PM
  5. Rockshox Maxle Lite 15mm thru forks and Hope Pro 2 Evo a play free fit?
    By Flat Pedals in forum Shocks and Suspension
    Last Post: 03-25-2012, 03:09 PM
