Hello,
I have a Spezialized Epic 2011 Brain Suspension.
If the rear suspension is working there is always like a mecanically block or impact in the end. Althoug the suspension works fine. I checked the air yesterday - I thought it would be because of missing air. The pressure was 7 bar, I raised it to 13 bar like given in the manual (around 82kg weight).
I already checked the given turns for the "Rebound" and "Brain" valves.
But this mecanically "clack" in the end stays. There is no "clack" you can hear, but you feel it if you are sitting on the bike. I hope you can understand my description.
Is this normal for this kind of suspension? Or is it time for a change of the oil or something?
Thanks for your help and/or opinions.
Best regards, Henning.
