Results 1 to 11 of 11
    Reputation: Rockrover's Avatar
    Enduro Taco Blade Removal
    Hey guys. Just picked up my new Comp today (super stoked!). I got a super deal on a XX1 group set and jumped on it. I'm going to install it in about a week. I didn't see a spacer in the goody bag when I got it the bike home. Should the spacer come in the kit, or is it purchased separately? Thanks guys!
    Mar 2005
    Spacer should be in bag. It just looks like a thick silver washer. It was a pain to get in my S-works frame as I think it was a hair thicker than the taco.
    Sent from my SCH-I545 using Tapatalk
    Yea it's not there. Talked to the LBS and no love there either. I'm going to have them order one through their parts and warranty rep. Kinda pisses me off. I had to ask for the bag that has the 4x cable retainers in it. When I asked they looked at me like I grew two heads...then they found it. When I told them I was going to route my stealth dropper cable the said it couldn't be done w/o drilling! a hole. When I told them about the cable hole they again looked at me like I just grew two heads. Their head mechanics didn't believe me so he busts out his Park Tool Allen wrench, pops the cable retainer off, and discovered it for himself.
    They're nice guys, but if it wasn't for this forum I'd be struggling with clustered together compromises made by my LBS's ignorance. O'well.
    Hey BTW, does anyone know if Pike supplied the tokens for the fork, or are thy purchased separately?
    Mar 2005
    Hearing stuff like this always makes me cringe. No shop should be selling products worth many thousands of dollars and not know this stuff. Heck, they have access to the interweb too, if I ran a shop you better believe I would want to know every issue people were finding with the brands I sold.
    As for the Pike, the 160 travel version comes with no tokens installed, since that is the base tune at that travel. If you didn't get them in the box, I imagine they are right next to that taco spacer They are cheap though, so I'd just order some. The forks bought aftermarket do come with 2 in the box.
    Dec 2011
    Anyone willing to part with their spacer? Moved and no local shops have them.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I have the spacer, I just simply dremeled down the taco (getting the spacer and bearing-shield in there is a real PITA). The spacer is a gold ring/spacer, similar to the other ones on the bike, slightly thicker than the others though. My 2014 didn't come with the spacer originally, I had to get it ordered from Specialized. I'd part with it cheap.
    My Enduro came with two tokens and the spacer and cable routers for both running 4 and 3 cables. Sounds like your LBS is lacking.
    You could just leave the taco blade in there until you can source a spacer. It won't affect anything, i guess just look ugly but then I think mountain bikes look ugly without FD's.
    mtbr remember
    Reputation: BikeSATORI's Avatar
    Anyone have a Specialized part number for the spacer? I just picked up a 2016 Stumpy Comp Carbon and I didn't see one included with this either...
    I'd imagine they would have included it in the parts bag since so many customers switch to 1X setups!
    Reputation: Silent_G's Avatar
    Oct 2010
    Specialized has no part number for that spacer. ALL those bikes come with spacers, two volume commentators for the fork, valve stems for tubeless and all the parts for 3/4 cable routing. Make your shop produce those parts, you've paid for them.
    I had one of the first e29s, the parts weren't with the bike. I eventually got them all, but had to go back several times. I just ended up dremeling down the taco, as I had taken it on and off a few times to get at the bearings and other stuff. The taco is hard enough to get on there IMO, the spacer is damn near impossible.
    mtbr remember
    Quote Originally Posted by Silent_G View Post
    Unfortunately no taco spacer included with the 2016 Stumpjumper Comp Carbons... believe me, I triple checked!
    I wanna pull that ugly sucker out of there... looks ridiculous with no front derailleur. ..might just dremel it down to make it into a spacer as others have done.
  1. Lyrik Dust Wipers Removal/Enduro Seal Install.
    By Falling in forum Shocks and Suspension
    Last Post: 04-13-2014, 06:34 AM
  2. Front wheel removal for 07 Specialized Enduro
    By johnd11 in forum Beginner's Corner
    Last Post: 09-21-2013, 04:56 PM
  3. What saw blade to fin aluminum?
    By Clipless in PA in forum Lights DIY - Do It Yourself
    Last Post: 07-25-2012, 05:33 PM
  4. Beaver Blade
    By tjp in forum Trail Building and Advocacy
    Last Post: 05-27-2011, 02:35 PM
  5. XT lever blade removal
    By Valtra in forum Brake Time
    Last Post: 03-18-2011, 04:36 PM
