Results 1 to 10 of 10
    Sep 2003
    Enduro suspension setup
    I would be very grateful if any Enduro riders would post info on their suspension setups.
    Air pressure, rebound adjustment and rider weight if possible.
    I have an 04 Expert that I am constantly tweaking.
    Old fart
    Aug 2005
    Rider weight: about 195 with gear
    Air pressure: 180psi
    Rebound: A couple clicks slower than middle. Sorry can't remember how many clicks from full slow...
    Yeah baby!
    grumpy northerner
    Weight: 245
    Pressure: 230
    Rebound: Same as micke - couple of clicks slower than midway-ish.
    Caveat: I'm running an RP3 rather than the stock Float R (same stroke, slightly longer eye-to-eye).
    Apr 2005
    are those rear shock settings?
    grumpy northerner
    Yeah - at least, I assume that's what the OP wanted...
    Life is Good
    Reputation: Judd97's Avatar
    Jun 2005
    I ride a 2002 Enduro and I have the rear shock set at 150 psi (I weigh 150) and I have the rebound around the middle.
    Front fork (Marzocchi MXC) I run at 50 psi in each leg.
    Demon Cleaner
    Reputation: Structure's Avatar
    I also ride an '04 Enduro Expert
    I also fiddle with the suspension settings. So I can't claim to have found the perfect mix, however, my current set up is about like this:
    rear float RL@160lbs damping at one click faster than center
    TALAS RL @75lbs damping centered (It feels less harsh with the damping slowed a bit, but handles better at speed with slightly faster rebound)
    In gear I'm about 185lbs.
    Bicycling is politics by other means.
    Reputation: Murchman's Avatar
    04 Sworks Enduro
    Rider = 220
    Rear PSI 220
    Rebound is 3 clicks from full slow
    Talas 55 PSI
    Rebound is 6 clicks from full slow ( I think )
    Basicly I setup my PSI for 25% sag front and rear, and my rebound is setup up to be quick up front and a bit slow in the rear per the Fundamentals DVD. Seems to handle really well that way.
    03 Enduro Pro setup...
    I have the 03 Enduro Pro with Marz All Mtn 1 130-150mm, Fox Float RL and BETD linkage plate.
    Rider weight: 180 lbs with gear
    Fork: 25psi (25% sag) at 150mm (All Mtn1 is a low pressure fork) (I ran the TALAS at 65 - 70 psi and 3 clicks from fastest rebound)
    Marz Fork Rebound: 5 clicks from fastest rebound
    Shock: 180psi w/ BETD link (6" travel), 160psi w/ stock link (25% sag) (5" travel)
    Shock Rebound: 5 clicks from fastest rebound
    Reputation: GuruAtma's Avatar
    I have an 04 expert and I go by sag rather than pounds of pressure. I keep pumping till I have about .5 inches of sag (or about 25% of the stroke). For rebound I ride off a tall curb sitting down. As long as I only "bounce" once, then I know I'm good. I keep the rebound as fast as it goes without getting more than one "bounce" off a 10" curb.
    功夫大师喜欢骑着他的自行车在山上。
  1. Trade-offs in anti-squat suspension theory
    By derby in forum Bike and Frame discussion
    Last Post: 05-24-2010, 03:46 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. rigid vs hardtail vs full suspension
    By old_dude in forum Bike and Frame discussion
    Last Post: 11-18-2004, 03:37 PM
  4. more mistaken 4-bar analysis
    Last Post: 03-11-2004, 05:20 PM
  5. Please explain the difference between ICT and HorstLink
    By BanzaiRider in forum Bike and Frame discussion
    Last Post: 02-28-2004, 12:55 PM
