Results 1 to 10 of 10
    Enduro SL's w/ different suspensions ?
    Any Enduro SL owners ditch the E150 / AFR for a different set-up ? I am looking @ purchasing an SL frame and installing an RP23 in the rear and running a Pike Dual Air up front. Thanx
    Reputation: Industrial's Avatar
    Maybe you should consider a Pitch. Unless you are going for the carbon enduro frame.
    Reputation: tonys102's Avatar
    Yeah - the Pike might be a little short. What about a Lyrik or a Fox 36?
    Building: ​Boardman 2010 HT Pro
    Current Joy: '11 Giant Anthem X
    Previous Joy: '09 Commencal Meta 5 VIP
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    yeah like Tony mentioned, the Pike will give you a steeper head angle and lower your BB.
    I run a Lyrik and Fox RP23 on my Enduro SL. She's been happy and going strong ever since!
    The new 08 Fox 36 also looks like a killer fork.
    Quote Originally Posted by Industrial
    It would be a Carbon SL - but why a Pitch or carbon ? What is the axle to crown height on the stock E150 ? Thanx
    he who goes without food
    Reputation: diskus's Avatar
    TALAS 36 works great
    Just Wanna Ride!
    If you already have the Pike, then run with it. The Pike will steepen up the head tube by around 1 degree and lower the bb, but it would make for a great long travel XC bike! BB will drop but will still be higher than on the SJ - should be ok even with the longer travel.
    I say ride it. Pike, Lyric, Fox 36 - the bike will rock, it will just handle a little differently than with the 150.
    You could always ebay the Pike and trade up.
    Quote Originally Posted by keen
    Just figured I'd throw it out there since it's a new model that looks pretty much like an enduro with a pike on it already. There is no pitch equivalent to the carbon enduros though so nevermind.
    I have run a Float & Vanilla 36, Z1 FR 1, and the Pike on my last few bikes. I think I prefer the Pike overall. If I hadn't run a Pike Dual Air i'd probably think it was sub par to the larger 6" forks but it holds its own. I was also really concerned w/ a 517 a-c height i'd be running steep - the dual air rides high in its travel. Now if the Lyric was a dual air I might take a look in its direction. Does anyone know the E 150 a-c height ? Thanx
    Reputation: Demodude's Avatar
    I have a marzo 66 waiting in the wings for when the e150 blowwwwwws
    I'm GNARcissistic
