Results 1 to 3 of 3
    MassiveAttack
    Reputation: massiveattack's Avatar
    Enduro SL Sizing... adjustments?
    I've recently picked up the enduro sl after riding a nomad & blur.... and am having a hard time coming to grips with getting into position when going downhill. The rig feels tight and somewhat difficult to angle given the I don't have enough room to extend my arms and body back. I'm 5'11 and went with a medium size frame and suspect that I may have gotten the wrong size.
    Is there anything I can do to maybe adjust, to accommodate my riding style and height? possibly raise the forks or extend the stem size, get longer bars or anything I can do with the rear??
    Thanks in advance.
    DSG
    DSG is offline
    Your frame does seem a little on the small side. I'm the same height as you and run a large.
    There is no real substitute for the correct frame size, but do you have a Thomson laid back seat post? That would shift you back a little and give you more room?
    May 2005
    Shock should be in DH position.
    I have a 100mm stem I will swap for your 80mm if you want to.
