Results 1 to 15 of 15
    ENDURO SL headset
    can I change it to something else?
    thiking to go either with the CK or the HOPE
    thanks
    no help?
    well , you can change it -----but you need to make sure that if you get a ck ---or what ever you chose ,
    that you get the oversized cups for the specialized head size.
    most head sets are 33.9mm ---you will need the 34.1mm cups to correctly fit tightly in the head .
    you need to ask for this oversized cup size generally -------
    anybody used this?
    http://www.crankbrothers.com/directsets_sagec.php
    can you advise good headset from this site www.chainreactioncycles.com
    for my enduro sl ?
    May 2005
    Why are you wanting to change out the Headset? If the bearings are bad you can get bearings the fit the headset from Enduro for $16.00 each and not have to worry about anything else involved with changing a headset
    because i have only frame without anything.
    i build custom enduro sl and now choose headset+shock+fork))
    May 2005
    Go heavy duty Stainless Steel Cups like this:
    http://www.crankbrothers.com/directsets_opiumsl.php
    Cane Creek 110 is a good looking head set with 110 year warranty as well.
    tnx.
    The Enduro SL uses 1 1/8" threadless, Campy spec integrated sealed cartridge bearings. They drop into the frame.
    Quote Originally Posted by gef73
    so,I can use any headset as long as they are 1 1/8" threadless??
    mine is Enduro SL Expert
    Reputation: crispycritter's Avatar
    Bapesta just get a 1 1/8th chris king pressed in there by someone with a proper hset press and forget about it for ever.....
    Quote Originally Posted by crispycritter
    yea...will them soon...thanks
    make sure you get the oversized cup for your head or it will spin loose and you will have a click and creak you can not find -----( and oval out you head tube in your frame )---
    and i believe it only comes in one color
    Reputation: Walt Dizzy's Avatar
    Aug 2003
    Where to buy?
    Kelstr:
    Where do you get the oversize headset?
    I changed mine from stock, now it is creaking and driving me crazy. I have an '03 Enduro base model. Where can I confirm that I need the oversize headset-or not?
    Walt
    you should always measure the steering tube holes ----and of course the old cups that came out of the tube if you have them -------if the cup measures 34.1 or so mm then its the oversized , ---if the cup measures 33.9 or so it is the smaller one .
    the last one i did for a customer , i had to call ck and spacifically ask for the oversized cups ----and he had me give him the measurments of the holes .
    and at that time they only had black -------they may make other colors now i do not know .
    but yes, they will creek , spin and can ovalize you head tube in quick order .
    i also locktight the cups in the head tube .
