Results 1 to 3 of 3
    Enduro SL fork question
    When i set the attitude and lower the fork, ive noticed that if im off the bike and let it sit for extended amount of time (10-20mins) the fork slowly extends back to full length. If i then put weight back onto the fork it will lower like its supposed to.
    QUESTION: Is this supposed to happen?
    Thank you in advanced.
    There is a little bit of air in the travel adjust feature to allow the oil to flow between the high and low position in the travel adjust. Cycle the fork 10x from high to low to get the air in its appropriate chamber. This should allow the fork to stay in its locked position. If cycling the fork 10X does not work and the fork returns from its low position in a matter of seconds, you can have the cartridge exchanged.
    Thank you very much for the prompt response...I will try this and get to my LBS if your remedy doesnt work.
