Results 1 to 10 of 10
    May 2005
    Enduro SL Comp Cane Creek Lanusse Headset
    Well,
    The headset on my Enduro SL Comp has a bad bearing. The plastic retainer inside one the bearing is cracked and made a "clunk" sound when it was in the top cup. I repacked both bearings and put the bad one on the bottom and the better one on top and the clunk has stopped for now.
    My questions are:
    Does anyone have one of these bearings they are willing to part with? I don't think it is a standard bearing as it has beveled edges and there is no numbers that I can see on it anywhere. I am South Korea and getting LBS support is tough due to language barriers and the "You did not buy it here, from us" factor I seem to get.
    Does anyone happen to know the number of this bearing? I can get bearings easily, but I need the number.
    I was thinking of going with a Chris King Headset, but that will be a challenge as well because their headset cups are 39.9mm OD instead of the 34mm OD Specialize uses on this bike. I can swap cups with CK for $25.00 and shipping, but really donít want to wait that long. Plus you can only get black when you do this, I want to be Golden like stock. So, what are the pros and cons of using a 39.9mm CK cup on this frame?
    Thanks for replies,
    PB
    i have seen problems with CK head sets ------even with a head tube that should have accepted the 33.9 cup
    i am really pick on press in parts on any type of macheinry .--------
    and most of the head tubes on the newer specialized frames are 34.0 so you need at least a 34.1 OD cup to fit even slightly correct .( i actually like them tighter than that , but thats just me )
    i generally have to make dam sure what size cups i need for a givin frame and you can call and get the oversized cups sent to you .
    but like you say , it takes time and its a pain to get the color you want .( generally you can't get the color you want )
    i will see if i can't get you a bearing number to help
    I'm "bad" different
    Reputation: WeezPuff's Avatar
    I just put the Enduro Max bearings in my headset since I misplaced the originals while I was rebuilding the bike. I really need to quit drinking whiskey while working on the bike.
    http://www.enduroforkseals.com/id178.html
    May 2005
    Quote Originally Posted by WeezPuff
    Thanks WeezPuff, those seem to be the bearings used. And after extensive web searches, no one lists that bearing size so I bought two from Enduro plus a set of the ESI Racers Edge grips. I have the Chunky grips now and they are truly awesome. Hopefully the Racers are just as good.
    PB
    i could not find anything on just bearings either , -----.
    so its good WeezPuff drinks wisky , -------he found enduro max bearings !!
    Quote Originally Posted by PB Matrix
    PB
    are you still using that 100mm stem ?
    May 2005
    I prefer Rum and Coke Zero myself. Great stuff that rum is.............having some now as a matter in fact....
    Yea, I have that 100mm mounted now. It helps with my gorrilla like arms and short legs. But it is a bit heavier, did you want it back? I'll trade for the 80mm again if you can score me a 25mm hub and axle.
    i am glad you found it to work for you , ----i really need to get the 60mm to work for me for i ride the poor bike but i just keep going back to the 100 .
    i have been keeping a close eye and trying to snag a hub and axle , ------but the guys know what they have and generally don't leave these behind
    Now with More Wood
    Reputation: Iceman2058's Avatar
    60mm stem was an awesome upgrade for me. Got the bike just where I need it now...good for light DH/FR and still able to pedal all day if need be.
    Quote Originally Posted by Iceman2058
    you are correct , ---my brother and oldlady both use the 60mm stem and just love it.---
    as so do several of my buddys.
    i on the other hand just really like the feel of the 100 on my XL bike , -----for some reason the smaller length stem ( 80 or 60) on the XL bike just makes it really twitchy and it wants to push the ft end .
    i have some different chassis set ups i want to try in order to run the 60mm stem on the XL bike, but i have not have time to get to it on my own bike
    its so funny , my bike is dam neer set up just like yours and they almost look the same ----except mine is the goofy looking XL one ---------its about the size of a honda civic
