Results 1 to 2 of 2
    Reputation: Steve.E's Avatar
    Enduro SL 25mm stout front hub measurements for spokes
    Hi all, I'm thinking of building a wheelset with ZTR Stans Flow rims on the stock Specialized Stout front hub from my 2007 Enduro and a rear hope pro 2 qr.
    I've found the measurements for the pro 2, but can't find anything on the front hub.
    Does anyone have accurate measurements for the spoke pcd's and offsets? I'm not sure how to do it myself.
    ARGH, forget it, I've searched for at least 30 minutes then a few posts down in this thread: Enduro SL 25mm Front Hub Alternatives the ever-helpful-specialized-encyclopedia that is PB_Matrix has already answered my question.
    Here is a quote for any other budding wheel builders who ever search the forum for this question!
    Quote Originally Posted by PB Matrix
    For OEM Specialized 25mm Disc Thru axel E-150 Hub wheel builders:
    Pitch circle diameter Left 58mm
    Pitch circle diameter Right 54mm
    Flange distance Left 23mm
    Flange distance Right 33mm
    Spoke Hole 2.7
