Results 1 to 3 of 3
Thread: enduro shock
    Listen! enduro shock
    I have an 03 Enduro (Large Frame) with a fox float R rear shock which is now blown. The eye to eye on that shock is 7.625 but the eye to eye on most of the new fox shocks is either 7.5 or 7.875, or at least thats the closest measurement they offer right now (im looking to get an RP23). Will getting the 7.875 eye to eye mess up the geometry of the bike or is it close enough where it shouldnt matter??
    Reputation: Rock's Avatar
    Close enough...
    I had an '03 Enduro Comp. The Fox w/Itch Switch stopped working. It was fixed under warranty, but while it was being sent off I purchased the Float w/ the 7.875" length. I found no problems with a VERY slight geometry change.
    You could also run alittle more sag to compensate if you felt it was nessesary.
    Rock
    Reputation: socalenduro's Avatar
    Nov 2006
    you can keep an eye out on ebay for odd ball shock lengths.
    another option is sending it to Push to have them rebuild it. It would most likely perform as good if not better than a new shock for the same price or less
