Results 1 to 7 of 7
    Enduro RP2 air pressure
    I'm looking for air pressure recommendations for 2010 or 2011 RP2 Enduro. I weigh about 160 lbs and prefer a more firm XC ride. I'm not sure how to set by using sag. I'd rather hear some psi recommendations and fine tune from there.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    170 psi
    clink link and go down to page 8 it should be healpful
    http://cdn.specialized.com/OA_MEDIA/..._Manual_r1.pdf
    The Unaffiliated
    That chart is a bit confusing. My 2010 came with a RP2 w/BV, which isn't on the chart.
    The chart only has RP23/BV and RP2. I found the RP23/BV pressure setting to be much better. About a 30psi higher.
    BV = Boost Valve, btw
    UNDEAD
    Reputation: snow-man's Avatar
    Go by sag
    Find your happy spot, bring a pump with you on the trail to adjust if needed. There is a "sagotron" sticker on your frame that lines up with sag readings on rear shock link...either 20% for firmer or 30% for softer.
    Pretty easy
    Quote Originally Posted by snow-man
    Go by sag
    Pretty easy
    +1
    Thanks hitech that's what I was looking for.
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    I'm 180lb and have my shock @ 210-215psi to get between 25-30% sag. Feels good, never bottoms out but nearly achieves full travel
