Results 1 to 2 of 2
    jurriaan
    Guest
    enduro rear shock
    is't possible to replace the Fox float for a Fox Vanilla RC?
    Quote Originally Posted by jurriaan
    There is no aftermarket shock which is compatible with the OEM shock which is spec'd at 7.625x1.875. That said, if you do a search of these forums, you'll find that there are folks out there who've managed to substitute a slightly different sized Fox Vanilla (and some other shocks too) for the OEM shock. As I recall, there were some other difficulties in getting the Vanilla to work in place of the Float, so you'll want to read these threads carefully before proceeding. It would almost certainly void your Specialized warranty too.
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. K2 Razorback Noleen Mega Air rear
    By MegaVolt in forum Shocks and Suspension
    Last Post: 03-30-2004, 09:28 PM
