Results 1 to 2 of 2
    Enduro Head Tube Angle
    Hi there!
    I had some time to waste, and measured the Head Tube Angle on my Specialized Enduro 2011, with the Lyrik 170mm and some 2.35 Hans Dampf tires on some Flow rims and the angle measured 64.5 degrees (Un-sagged)! Can this be right???? The manual states 66.5 I know this could be a bit of, but 64.5 sounds reaaaaly slack to me.
    Anyone out there can confirm or comment on this?
    Thanks!!!
    Reputation: jimw's Avatar
    Highly unlikely that's accurate. Even the slacked out Enduro Evo is at 65 deg. How are you measuring? Is your measuring device known to be calibrated/accurate? Measure it once, then flip the bike around 180 deg and measure again - the floor could easily be a couple degrees off from perfectly flat.
  1. Head tube angle ?
    By dflash in forum Specialized
    Last Post: 10-14-2012, 06:49 AM
  2. Head tube angle?
    Last Post: 09-05-2012, 07:05 AM
  3. Head tube angle
    By henrymiller1 in forum Frame Building
    Last Post: 03-09-2012, 04:23 PM
  4. ML1. Head tube angle?
    By moldau94 in forum Titus
    Last Post: 11-13-2011, 10:40 PM
  5. head tube angle
    By bfree in forum 29er Bikes
    Last Post: 07-26-2011, 02:59 PM
