Results 1 to 3 of 3
    Enduro 2011 rear suspension became loose
    Hello. I have a 2011 enduro and the rear suspension feels a little loose, I have checked everywhere and Im sure its the mounting hardware where the shock conects to the frame, remember the enduro shock is inverted, so it would be the lower part of the shock, it goes directly to the frame, not to the link. Does anybody knows where I can find this mounting hardware and what size is it. Is there an alternative solution to this problem, I have tight it more than enough and it still feels loose. Thanks.
    Bernardo
    Your killing my Strava
    Reputation: vinnyl26's Avatar
    Sounds like you have a bad DU bushing. Any LBS should have
    We will never know our full potential unless we push ourselves to find it.
    Lo mismo le paso a mi enduro comp tambien 2011, si la levantaba por el asiento se sentia un juego. Rodrigo vargas de dynamia vende los DU bushings que necesitas y te los instala!
    Saludos!
