Results 1 to 6 of 6
    Reputation: kcavtca's Avatar
    Mar 2005
    Enduro (150) - how many inches can the seatpost adjust?
    Could someone be so kind to post the range of adjustment? If you take the time to do it also mention what size frame it is since it looks like it would vary across the size range.
    Thanks,
    kcavt
    Reputation: simen's Avatar
    Frame size M, adjustment range approx. 13.5cm= 5.3 inches
    Mar 2005
    Quote Originally Posted by simen
    mmm, I was hoping it was more. Do you ever find yourself wanting more adjustment?
    I guess I could also get two seatposts to and solve the problem.
    I have a medium and just sent mine off so I cannot measure it, but I am pretty sure its more than that - its measured from the minimum hole to the bottom of the cut-off seat tube (max insertion).
    Measured it again. It's 15cm from min insertion hole to 5th piston. There's another cm less because of negative chamber valve that passes beneath the seatpost. So 13.5cm on M frame to be safe. I drop my seat for about 10cm max for gnarly dhs (I'm 178cm). Don't know for other frame sizes.
    Mar 2005
    Thanks. Sounds like its not its not something to be too concerned about. I'll just have to get one and live with it!
  1. Replies: 0
    Last Post: 08-03-2004, 11:39 AM
  2. Ti seatpost vs. Carbon seatpost
    By psOption3 in forum Weight Weenies
    Last Post: 04-12-2004, 09:00 AM
