    nothing to see here
    Reputation: Stevob's Avatar
    EBB on 2010 Rockhopper
    Can't use search function for "EBB" hence my question...
    Is the EBB on a 2010 Specialized Rockhopper SL Comp 29 SS fully rotatable 360 degrees? I read in a review somewhere recently that it only has 180 degrees of movement, but would like confirmation if possible please.
    Cheers,
    Steve
    I see hills.
    I want to climb them.
    That is correct. It only has around 180 degrees of movement and cannot be in the lower half of the bottom bracket shell, I know because I checked one out at my local bike shop.
    You can search for <4 letter words on mtbr using google. Type site:forums.mtbr.com then your search phrase. The only minus is that you can't search topic headings only.
    nothing to see here
    Quote Originally Posted by djembe975
    Thanks heaps for the info.
    Quote Originally Posted by mkselecta
    Cool tip. ta.
    I see hills.
