Results 1 to 3 of 3
Thread: E150 weight
    Feb 2007
    E150 weight
    So I've been searching around and can't seem to find out how much an 09 E150 fork weighs. Anyone have this info?
    Reputation: chameleoneel's Avatar
    claimed weight for the 2007 with integrated stem and 25mm thru-axle is 2.2kg or about 4.84 pounds.
    Quote Originally Posted by chameleoneel
    Thats about correct for the shorter S,M,L frame fork .
    My XL e-150 is just a tad bit heavier at just under 5 lbs, but thats with s-works clamps and ti hardwear .
    I also have an 09 s-works e-150 fork that I did not check the weight before I started modding it with a larger air cartridge and more travel , but it was supposed to be alittle less weight .
    But this is still dam light for a duell crown fork that is very stiff and can take a beating and is so versitle and strong.
