Results 1 to 3 of 3
    Feb 2007
    Dura Ace 7900 Front Derailleur on Stumpjumper?
    Has anyone tried mounting a Dura Ace 7900 front derailleur to a Stumpjumper Expert Carbon frame? I am running the S-Works double crank. I have seen it done on various other frames like Yeti, Trek and was interested to see if anyone has done it to their Spec. If not, I will be the guinea pig and will report back what happens.
    Usually road derailleurs are bottom pull and I would guess the routing on your Stumpy Expert are on the top tube (top pull).
    Why not just use a double mountain derailleur?
    Feb 2007
    Weight weenie build
    I am using a Speen adaptor that converts bottom pull front derailleurs to top pull.
  1. XX Triger + Dura Ace 7900 FD is it possible?
    By adib72 in forum Weight Weenies
    Last Post: 05-13-2013, 02:21 AM
  2. Dura Ace rear 7900
    By red5jedi in forum Weight Weenies
    Last Post: 09-06-2011, 04:23 PM
  3. Dura Ace 7900 front derailleur with Shimano triggers
    By Danne in forum Weight Weenies
    Last Post: 01-28-2011, 08:21 AM
  4. will a dura ace 7900 r. derailleur work
    By eride1 in forum Downhill - Freeride
    Last Post: 12-02-2010, 10:04 AM
  5. Dura Ace 7900 front derailleur
    By racerick in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-02-2010, 02:02 AM
