Results 1 to 5 of 5
    Dec 2004
    DU Bushings - A better alternative???
    I'm riding an 04 SJ FSR. The original bushings lasted over a year, until I noticed what I now know is "The Play". Since then, I've had to replace the bushings twice, each set lasting only 6-8 weeks. Does anyone know of a better alternative that will fit the SJ with the triad shock? PUSH, Jon Whyte....anybody? Thanks.
    Reputation: consumerbydesign's Avatar
    Jan 2005
    Beer can
    Cut to fit.I suppose rubber might be healthier.This might not be good advice.
    Jun 2005
    If your reducers are 35.5mm wide then you can use the Whyte bushings. Guaranteed for life.
    Quote Originally Posted by RkyMtnHigh
    If yours is the newer frame style, do you have a "mudflap"?
    I'm convinced the main problem is the lower shock bushing is getting everything thrown off the tire, and the mudflap getting in the way should make a huge difference in bushing life. My '01 doesn't have that option, so I replace the bushing and reducers more than I would like. My upper bushing and reducers last way longer, which is why I think tire-debris is the issue.
