    Contains no juice.
    Nov 2003
    Do these look like the correct bearings for an '03 Enduro/Fox Float R? (X-post)
    Sorry- I posted this over in the shock forum, too. Just wanted to cover my basses.
    I'm getting a lot of play in my rear end (ow!). When I lift the bike off the ground by the seat, I can feel slop in the shock where it connects to the Flip-flop link.
    Do these bushings look like the right ones? I want to make sure before I start to take everything apart.
    Thanks,
    fp
    Is my paycheck just a bribe to forget my dreams?
    Part number is...
    08DU08...which should be embosed on the outside of the bushing. You should be able to order them from any local bearing supplier.
    Contains no juice.
    Nov 2003
    Hmmmm.
    Quote Originally Posted by Dutch
    Mine reads: 08DP08 in squished numbers, then 0307 in regular-style numbers.
    Close enough?
    fp
    Not sure...
    Call a bearing supplier and ask if they are the same. I believe the second set of numbers refers to a manufacture date ie. July/03.
  1. Do these look like the correct bearings for an '03 Enduro/Fox Float R?
    By Finch Platte in forum Shocks and Suspension
    Last Post: 03-20-2004, 04:42 PM
