    Disc Brake Newbie Question
    I purchased a Specialized Hardrock Sport Disc 29er over the weekend and this is my first disc brake bike. My question today is about storage. Can these bikes be hung upside down from the wheels on the ceiling or will I damage the bike in some way? Do they need stored right side up? I don't want to start leaking fluids or anything like that? Just figuring out a way to store them in the garage. Thanks.
    '11 Specialized Crux Pink SS
    '15 Trek Farley 6 Fat Bike
    '15 Specialized Fatboy
    '12 Specialized Crux Skittles
    old fart
    Quote Originally Posted by smoothie7 View Post
    The master cylinders (on the levers) will not leak.
    <100%
    Reputation: JackJr's Avatar
    Putting a bike with hydraulic brakes upside down will sometimes let air bubbles migrate into places they should not be (master cylinder, calipers). If your brakes are bled properly, it should not be a problem. As you start getting towards that point where you need a bleed, problems are more likely to occur. If the brakes go a bit flat, pump them up. If that works, pencil in a brake bleed for the near future. if it doesn't, it's time to bleed the brakes.
    old fart
    Quote Originally Posted by jsj3831 View Post
    Any air in the line (between the calliper & the lever) will affect braking regardless of where it is in the system (Master cylinder, hose or calliper). Having the bike upside down won't change this - the brakes should be bled.
  1. Newbie just rode Mission Peak, question about brake fading
    By lidation in forum California - Norcal
    Last Post: 02-04-2013, 10:23 AM
  2. Best Disc Brake setup- complete- for a 29er newbie
    By spistols in forum 29er Bikes
    Last Post: 02-08-2012, 05:30 PM
  3. Newbie Question: Brake Pad Comparison
    By NastyButler in forum Brake Time
    Last Post: 02-02-2012, 04:59 PM
  4. Another Disc Brake Question
    By Reice05 in forum Beginner's Corner
    Last Post: 07-28-2011, 05:11 AM
  5. Disc brake question
    By MtDude in forum Brake Time
    Last Post: 05-04-2011, 09:27 AM
