Results 1 to 3 of 3
    Differences in '09 and '10 Stumpy S-works
    I have an '09 Stumpy FSR S-works and am considering buying a '10 frame and swapping the components over.
    Just curious what (if anything) will give me a problem.
    I love my '09, but there is something about the '10 that I just can't get off my mind... yes I may be insane.
    Nothing will give you any issues, I did exactly the same swap and moved my parts over without a problem. I have an XTR m970 chainset that fitted with the Shimano press fit cups. You probably are a bit mad but the 10 descends a fair bit better. It also climbs a little better,( IMHO) and the shock position works better, although I was initially sceptical of this. It is 10% better in all areas and more than that descending. Quite a feat over the excellent 08/09. The shocks, and forks if you get them as well are a little trickier to get dialled but better when you do.
    Thanks for the info Pete... there may be an '09 S-works frame for sale soon.
