Results 1 to 2 of 2
    Vitamin Bike Added
    Reputation: MTBCanuck's Avatar
    Creaking/poping noise from 2008 pecialized Stumpjumper FSR Expert
    There is a creaking noise driving me nuts on my new out of the box 08 Stumpjumper FSR expert. The creaking started after a fairly hard trail ride and sounds like a creaking/crackling from the frame. I checked all the rear linkage pivot points and lubed them well, checked the tension on all the bolts and still can't exactly isolate the source. I have numerous full suspension bikes and this is the first issue of this kind I have come across. I don't suspect BB or headset and the frame doesn't have any visible cracks. I know this is a huge shot in the dark unless someone else has had the same issue with their stumpy. Open to suggestions! Cheers.
    Keep the rubber side down
    Feb 2007
    Check your seat and seat post and make sure they are tight also
