Results 1 to 3 of 3
    Reputation: MarXC's Avatar
    Feb 2014
    Good job! Crave Expert or SJ Comp HT
    hi everyone.
    I use the bike every day to go to the University (30 km) and to climb the hill 2 or 3 times a week, mostly XC. I did not put the Crave Pro because is not in my country (Chile). There is a difference of $ 100 between them, with which you think should stay? The geometry of the SJ is more racing and maybe a little uncomfortable to travel 3 hours or more, in this case, the Crave would be justified by a more relaxed geometry?
    They are also possibilities: Kona Big Kahuna (2014) and Niner EMD 9.(1 Star) (2014).
    Thank you.
    Kona Big Kahuna --> KONA BIKES | 2014 BIKES | RACE LIGHT | BIG KAHUNA
    Specialized Crave Expert --> Specialized Bicycle Components
    Niner E.M.D 9 X7 1 Star --> E.M.D. 9
    Jan 2013
    Is the commute singletrack or dirt road or paved road? Just for commuting, there are probably better, cheaper all-road bikes like the Specialized TriCross (or Awol or Sirrus or other similar bikes from the big mfrs) unless you're actually doing singletrack and really, really steep climbs.
    For $100, it mostly comes down to geometry. Let the shop take the time to set up each bike on a trainer and see which one fits you better. If you are already doing the commute, then you should have an idea of what you like & don't like about your current bike fit.
    I preferred the Carve's relatively longer top tube compared to the SJ. At least on road bikes, the longer top tube is usually considered more aggressive, so I don't know why the SJ is considered more of an XC race bike based on its geometry. If anything it's relatively more All Mountain than XC when compared to the Carve/Crave (based on chainstay length and top tube length).
    The SJ HT compares pretty closely in spec to the Crave Pro, not the Expert. The SJ will be a little lighter and parts should work a little better, but it won't be a huge difference.
    Feb 2014
    understand, then even with Crave Comp would be good for my training. it's just that I wanted to have a Reba fork or is not much difference with a Recon Gold TK SA 29 SL. between the Expert and Comp, change only the transmission fork and think.
  1. 13 Carve Comp vs 14 Crave or Rockhopper Comp for Clyde?
    By dkyser in forum Clydesdales/Tall Riders
    Last Post: 02-16-2014, 08:09 AM
  2. Replies: 6
    Last Post: 08-30-2013, 05:57 AM
  3. Replies: 0
    Last Post: 08-10-2013, 10:27 AM
  4. 2013 Stumpjumper Comp or 2014 Crave Pro ?
    By JoeOxfordCT in forum 29er Bikes
    Last Post: 07-26-2013, 11:22 AM
  5. 04' FSR Expert VS. 06' FSR Comp Frame
    By phins420 in forum Specialized
    Last Post: 08-03-2011, 02:43 AM
