Results 1 to 9 of 9
    Reputation: WVBikr's Avatar
    Cracked Alum Stumpjumper
    I have a cracked Aluminum 2011 Stumpjumper, will Specialized send a replacement before I send it to them?
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    You should ask your LBS/Specialized dealer. My gut says no....
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    of course not.
    That's what my LBS is saying that's why I'm coming here.
    May 2012
    Do you expect Specialized to just take your word for it?
    Reputation: TwoHeadsBrewing's Avatar
    You have to take it to the shop and have it checked out by a tech. They'll start the warranty process with Specialized. Specialized, like most bike manufacturers only deals with bike shops, not end users.
    "Got everything you need?"
    Reputation: SenorSerioso's Avatar
    Don't forget: assuming your warranty is processed (or crash replacement depending on the circumstances) the process does not cover labor for disassembly and reassembly.
    Dec 2009
    1) do you have the original receipt?
    2) was it a crash, or a legitimate crack from wear and tear?
    I expect shop to inspect and take pictures if needed so frame can be on the way. That way I have least amount of downtime possible. Yeah legitimate crack at a weld where seatstays join each other
