Results 1 to 5 of 5
    Coilover shock w/ 2007 FSR XC frame possible?
    Is it possible to fit a higher end coilover in the 2007 FSR XC frame?
    Reputation: mr.specialized's Avatar
    Hope so but doubt it....
    Would it adversly effect the handling [and or the rear shock] performance if You put a 130mm fork on an XC?
    It would certainly raise the front end and slacken the head angle, raise the BB a bit. If you do mostly downhill you might enjoy it but will definitely hurt you a bit on the uphill.
    Ah! But climbing would be a breeze via a u-turn nob
