Results 1 to 8 of 8
    checking out a hardrock
    I think i will go look at a Used 2009 hardrock disc tomorrow i found online. It will be my first Real MTB
    I Found out i live really pretty close to some trails mainly single track by my house just want to know how good of an idea a Hardrock is for my first bike?
    Never ridden them before and want to see if i like it. ( I love biking ever since i was 4 but just on bmx bikes)
    If i find i like the sport will i find myself trying to sell this bike in a year and trying to upgrade?
    Just wondering if i bring it home what should i expect?
    Whats a fair price for a used 2009 hardrock disc in prime condition.? (dont wanna get burned)
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    send us the link
    Honestly... ahh I give up
    Reputation: Sourheart's Avatar
    May 2010
    I just bought a 2010 Sport Disc and it's a really nice bike. And while i don't think I will HAVE to upgrade to a better bike in a year I will WANT to upgrade some things on the bike. So far the only thing i want to upgrade is the fork, it sucks. It doesn't suck so bad that it takes away from the fun i have on the bike though.
    So if you like the bike and it's a good price, get it.
    There is a picture
    says has 50 miles on it
    what would be a good price?
    ~Disc~Golf~
    I can't really see
    got anything bigger
    or a spec list?
    or the link to where you found it?
    The specs/components would be stock i am assuming. so the list on the specialized website for this model/year is prob accurate. and i posted that below.
    Specialized A1 Premium Aluminum, fully butted, formed TT, double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 hanger, disc only
    REAR SHOCK
    FORK
    SR Suntour SF8-XCT-V2, 80mm, 1pc. alloy lower, 28mm Hi-Ten stanchions, 13-15": standard spring, all others: "stiff" spring, coil/mcu spring w/ preload adj., spring assisted seals, disc only
    HEADSET
    Specialized 1-1/8" threadless, loose ball
    STEM
    Specialized forged alloy, 15 degree rise
    HANDLEBARS
    Specialized Hi-Ten, 32mm rise, 640mm wide, 8 degree back sweep, 6 degree up, 1.6mm thick
    GRIPS
    Specialized Enduro, dual compound Kraton, no flange, 131mm
    FRONT BRAKE
    Tektro IOX, mechanical disc, caliper/adapter w/ 6" rotor
    REAR BRAKE
    BRAKE LEVERS
    Shimano (integrated w/ shifter)
    FRONT DERAILLEUR
    Shimano C-050, 34.9mm clamp
    REAR DERAILLEUR
    Shimano Altus
    SHIFT LEVERS
    Shimano ST-EF50-7, 7-speed
    CASSETTE
    Shimano MF-TZ31, 7-speed, 14-34t Mega Range
    CHAIN
    KMC Z7 w/ reuseable Missing Link
    CRANKSET
    Shimano FCM-191, polished
    CHAINRINGS
    42 x 34 x 24t
    BOTTOM BRACKET
    FSA BB-7420, cartrdge bearings, 68mm x 122.5mm for 47.5mm chain line
    PEDALS
    Steel cage, composite body, 9/16"
    RIMS
    Specialized HRD SW, 26", pinned, alloy single wall, 32h
    FRONT HUB
    Specialized Hi Lo, forged alloy, double sealed, ground race, disc 32h
    REAR HUB
    Specialized forged alloy, double sealed, ground race, disc, 3QR, 2h
    SPOKES
    1.8mm (15g) stainless w/ brass nipples
    FRONT TIRE
    Specialized Fast Trak LK Sport, 26x2.0", 60TPI, aramid bead
    REAR TIRE
    INNER TUBES
    Specialized schraeder valve
    SADDLE
    Specialized XC, Body Geometry, 143mm width, front and rear bumpers
    SEATPOST
    Specialized alloy two bolt, no offset, micro adjust, 30.9mm
    SEAT BINDER
    Specialized alloy w/ QR
    I am just looking for a price if for it were to be in pretty good condition? $300?
    can't go wrong with a HardRock. I had a 05 Hardrock Sport. Anything Specialized has my vote. Just my 2 cents.
    Reputation: sjreeves717's Avatar
    I started with an 09 Hardrock and really liked it. I bought it to cruise my daughter around the neighborhood. Then I found out some guys I work with ride trails. I tagged along one time and was hooked. After awhile I was able to keep up on the climbs and smoother terrain but when things got rocky they would just walk away and leave me. Also after a long rocky ride, I would come home feeling beat-up. I ended up buying a Stumpjumper FSR and sold the HR for $275. It's a great bike but if you already like to ride trails I would go full suspension right away.
