Results 1 to 7 of 7
    Chainline QX1 and S2200 Crank
    Anyone install a QX1 Sram spider with the S2200 or any XO or XX crank and notice the chainline. I am at aprox the 3rd smallest cog with being perfect. Nowhere near the middle. I have a S-Works crank with the S-Works QX1 Spider and it has a perfect chainline. Thanks...
    SRAM OEM cranks can be funky with longer spindles.
    Quote Originally Posted by the mayor View Post
    With same crank and stock spider the middle ring has perfect chainline. I actually had to reverse the Q-ring to get proper chainline but the ovality is way off, need to mess around with that to make it someone what it should be like
    Quote Originally Posted by gigabyte772 View Post
    That's because the stock spider was made for the longer spindle.
    I bet if you took a regular non OEM XO crank.... the Rotor spider would have a better chain line.
    Same thing happened with the S1400/ X9 cranks ( Go to the WolfTooth thread in the DriveTrain section....you will see)
    I went through it myself on my Cannondale Trigger
    BTW....thanks for the info on the Rotor spider....I just ordered one and a S Works crank.
    Yeah, I will be probably getting another S-Works crank for my bike then...
    The things we have to suffer through ;^)
  1. XX1 crank chainline (found the answer :))
    By Stuart B in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2014, 10:19 PM
  2. X0 crank PF30 chainline
    By KevinNZ in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-04-2013, 04:40 AM
  3. e.13 crank question & Chainline list
    By Widget in forum Fat bikes
    Last Post: 03-03-2013, 09:08 AM
  4. S2200 Crank Arm How to tighten properly
    By Tjay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-03-2013, 08:11 AM
  5. SLX Crank 2ring vs 3ring - Chainline
    By Grande in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-25-2012, 02:00 PM
