Results 1 to 5 of 5
    Aug 2013
    Can't seem to find an aftermarket 34mm seatpost collar
    New to the forum, found it searching for a new seatpost collar for my recently purchased 2012 crosstrail.
    I was raising my seat the other day, didn't realize I should've been using a torque wrench and overtightened the bolt which stripped out some threads .
    I was able to put a longer bolt in and with the help of a nut and some washers it seems to be holding but I'd like to upgrade the seatpost collar to one similar to the Salsa.
    Anyone know where to get a 34mm collar?
    May 2012
    Try:
    Universal Cycles -- Salsa Lip Lock Seatpost Clamp - Black
    Components > Saddles and Seatposts > Seatpost Collars | Jenson USA Online Bike Shop
    Universal has Salsa collars from 28.6mm to 36.4mm. Jenson has quite a few that are 34.9mm.
    Are you sure yours is exactly 34mm?
    May 2005
    According to the specs it takes a 31.8
    Specialized Bicycle Components
    Aug 2013
    Thanks for the replies. It has 34 stamped on the collar. I read the specs when originally searching online and thought it would be a 31.8 but my LBS said that it was a 34mm.
    Aug 2013
    I guess I should just purchase a caliper and be sure of it. I need one anyway.
  1. Where to find XTR960 middle chainring (32T) Shimano and/or aftermarket
    By patineto in forum Where are the Best Deals?
    Last Post: 05-02-2013, 04:06 PM
  2. 34mm seatpost
    By modbog in forum Trek
    Last Post: 08-20-2012, 03:06 PM
  3. Aftermarket seatpost clamp for TallboyC
    By nbwallace in forum Santa Cruz
    Last Post: 06-12-2012, 05:45 AM
  4. Need a non-slipping seatpost collar
    By loggerhead in forum Weight Weenies
    Last Post: 02-21-2012, 10:46 AM
  5. Flash Carbon Seatpost avaiable as aftermarket part?
    By steadyuk in forum Cannondale
    Last Post: 06-04-2011, 07:34 PM
