First, I have an issue with my right foot. Long story short is it sticks out. Enough in fact that I use a pedal extender on that side so my heel will clear the crank arm. Even with the extention, only certian cranks will work depending on how much ans were the bend is. The cranks on the camber comp work but, the cranks on the expert don't. As I am getting a Expert EVO, I will need to switch out the cranks. While I'm at it, I would like to get cranks that are slightly wider (Q factor?) as occasionaly, I hit the chain and seat stay on that side.
I measured the cranks on the comp (the bike I tested). I got 170mm from the outside to outside. The specialized rep said that he wouldn't trust the sram specs.... Any suggestions??
Thanks again for everybody's time.
