Results 1 to 26 of 26
    Sep 2012
    No good camber frame crack
    hi..
    bought a new camber frame yesterday when i try to fixup my new toy
    i found that there is a hair line crack at bb mounting
    so i sent back to get a replacement but ...........
    WTF....the replacement frame having a crack too on front tube where you fix the headset
    SPEACIALIZED...world leading brand such of QC before market their frame
    im veryveryvery disappointed
    Sep 2012
    Attached Thumbnails Attached Thumbnails camber frame crack-img-20120922-wa0008.jpg
    May 2005
    Wow
    Oct 2011
    No bueno
    Jan 2009
    yep, that's definitely a hairline crack. And it looks to have been weld repaired AFTER machining, but only one that small partial section?
    Looks like the QC guy in Taiwan missed that one.....
    Sep 2012
    QC guy not only missed out this frame.....
    they missed another 1 when the bikeshop try to exchange
    I Ride Bikes
    Reputation: Mazukea's Avatar
    Good eye! nice catch.
    Just received my new carbon camber less than 2 weeks ago and it sure sounds like it's cracked somewhere, but I sure can't find it. But it's LOUD!
    "Ride it Like You Stole it"!
    **** happens....and that is a pretty small crack that they caught but the weld didn't fix.
    It looks like a good weld too, so I wonder what is up with the crack.
    Thats pretty shocking alright
    Reputation: MObiker's Avatar
    My guess is that the front triangle is assembled and the BB housing is final machined before paint. At that point if a crack is noticed the assembly is too expensive to scrap out so it was decided to rework the housing by TIG welding the crack to prevent it from opening up further. I would like to see the test data that shows that the crack will not in time split the weld repair. The ID of the housing will also be a bit ob-round due to the crack.
    If the path ahead looks dangerous ------- it probably is!
    Sep 2012
    got my new replacement frame....but.....
    curious why additional welding needed
    this frame on head tube......
    Attached Thumbnails Attached Thumbnails camber frame crack-20120925_180022-1.jpg
    May 2005
    My 2012 Evo Stumpjumper 29er frame has similar "repair welds" in the head tube. I imagine the these are to cover up and or repair the hair line cracks produced during the welding of the top and down tubes to those thin area's of the head tube. So what, ride the frame, but check those area's for cracks monthly or less, just like you should be doing anyway, and enjoy.
    You are saying that a user should remove their headset and bottom bracket monthly to inspect for weld and metal integrity?
    I call bs.
    Probably one tube is welded all the way around. The next tube overlaps the welded area and is welded. You see the first tube's weld.
    Other marks are just good penetration. Check for interference with the steer tube before final install.
    lean forward
    May 2005
    Quote Originally Posted by jonshonda View Post
    I call bs.
    Um, how about just checking all the exterior welds monthly. And, the inside when you do your fork maintenance.
    junk
    Quote Originally Posted by PB Matrix View Post
    How about buying another brand that is not so focused on weight that they engineer a frame that fails during mfg - not acceptable to weld a crack - good luck and let us know if the head tube fails while you are riding!
    May 2005
    Name one common name brand manufacturer of bicycle frames using aluminum that has not had any of their frames crack or break.
    Name any frame manufacture that you know that does not re-weld or otherwise repair a raw frame before it is painted. Do not guess, show proof, as they will have my future business.
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    The sections of weld you can see coming through the tubing are the root of the outside frame weld, usually from a bit too much heat or the tubing being a little thin. The weld itself will still be nice and strong.
    I think it is pure coincidence it lined up with the hair line crack in the BB. If it were welded from the inside you would see the etched cleaning path that is produced around the bead from AC tig welding, like you can see in the fresh weld in the HT. In saying that the hairline crack may have been from incorrect preheat of material causing the crack when cooling. Alloy like to do that.
    My gut feel is the weld inside the HT is a spot weld to aid assembly but I could be wrong since they should be jigged up before welding
    Sep 2012
    i got giant anthem/Scott/cube/xds bike....but never saw any internal additional welding
    Reputation: CarManDSL's Avatar
    That does not look like a weld from this perspective. At the end of the hair line crack it appears to be machined out by hand at the end of the crack using a small ball grinder bit. This is common practice to prevent a crack from going further. Not to say that's acceptable on a new frame, but a repair that can be done on any frame to prevent further cracking if the crack isn't too bad in the first place.
    That is why your seat tube at the post clamp has a vertical slot with a drilled hole at the bottom. This is to allow for the tube to compress slightly to put pressure on the post. If no hole, the slot would form a crack down the seat tube.
    17 990 Element BC Ed - 25.5 lb burly
    15 Enduro Expert 29, SW build - 27.6
    14 SW Epic WC - 21.8
    12 Niner Air9RDO -16.4
    Well . . . if I turn my head sideways to view the photo and imagine looking down a head tube, it does look like a weld.
    Sep 2012
    what i mean is the brand name QC and im paying thousand over USD for the frame.......
    May 2005
    Any updates on your frame ?
    I see some good deals on this bike, but am now concerned with this issue.
    Oct 2012
    holy **** somebody need tobe punched for that
    Oct 2012
    Yea, seriously for the prices we pay for them, you'd think maybe they xray the frame after paint /before shipping so maybe someone doesnt get F'n busted up and die on a run?? Or am I once again expecting waay too much... how the F is this allowed in the first place? THERES NO WELDING IN BASEBALL, er.. Bicycle frames..!!. You dont fix it up in 'post production' and hope no one notices, its a FAIL! you scrap the damned Frame and give your customers something 100%SAFE! Or sell it as a factory second with a hearty Hi-Ho and 'good luck' on the trail... Were supposed to bust them up, not the damned Manufacturer!!!
    This kind of crap is why I tend to slightly hate the world.
