Results 1 to 6 of 6
    Feb 2012
    Camber comp carbon, delivered with 120mm fork?
    Hi, I recently bought a Camper Comp Carbon 2015 model. I was planning to shift the fork to a 120 mm Revelation. When I measured the stanchion of the Fox fork thatīs on the bike itīs 120 mm. It should be 110 mm. What am I missing?
    lurking no more
    Reputation: nocnypatrol.org's Avatar
    deflate it and check how much it suspend its travel
    Jan 2014
    It may only have 110mm of travel before bottoming out.
    2014 Stumpjumper EVO HT
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    A lot of times Fox forks show more stanchion than the travel they have. A few years back the Stumpy came with a 140mm Fox 32, and people would measure the stanchions and come up with 150mm, but when you bottomed it out riding you could never use that last 10mm. I was told Fox designed it that way to prevent the crown from banging into the lowers.
    2013 Stumpy Evo
    2014 Fatboy
    Reputation: Biking Brazilian's Avatar
    Someone got an EVO!
    Feb 2012
    Thanks for the answers, I also think it just have 110 mm travel. I have tried to bottom it out when riding but never use the last 10 mm. A revelation should be a good switch then, same AC height and 10 mm more travel.
  1. Camber Comp -110mm or 120mm
    By uppo in forum Specialized
    Last Post: 07-03-2014, 04:33 PM
  2. 120mm Fork for 2011 Camber comp frame
    By reimorei in forum Shocks and Suspension
    Last Post: 02-21-2014, 08:45 AM
  3. Replies: 2
    Last Post: 10-16-2013, 07:30 PM
  4. Spec. Camber Comp Carbon 29er Fork Upgrade
    By GnarBrahWyo in forum 29er Components
    Last Post: 12-02-2012, 03:45 PM
  5. Advice needed. 12 Camber Comp vs 12 Camber Carbon
    By moto67e in forum 29er Bikes
    Last Post: 07-10-2012, 11:43 AM
